GM Sychro mesh !!!!!!!!!!!!! IT does work try it for yourself
Old Mar 24, 2005 | 08:29 AM
90HFCrX's Avatar
Default GM Sychro mesh !!!!!!!!!!!!! IT does work try it for yourself
hey everybody i no this has been covered before i was reading through the old articals about this stuff. I mean i have tryed everything on my b16a ys1 tranny. I can say that **** is expensive but it's well worth it. I could tell a big difference from the minute i put the friction modify the stuff looks like it comes in a regular oil bottle. as i drove it got better and better. All i gotta say is for the people out their that are thinking about trying it. Do yourself and your tranny a favor try out what can it hurt. You WONT BE SORRY THAT YOU DID!!!! thanks again honda-tech peeps I think i payed like 11 or 12 bucks a quart.
Old Mar 24, 2005 | 08:44 AM
ButterMule's Avatar
Default Re: GM Sychro mesh !!!!!!!!!!!!! IT does work try it for yourself (90HFCrX)
yup.. same experience here, my b16 tranny was grinding alittle when id put it into 5th, spent $30 at GM dealer, got the syncromesh and the grinding has completely gone away. GM Synchro mesh
Old Mar 24, 2005 | 08:48 AM
EJ2-Fluffy's Avatar
Could use this stuff as well.
Pennzoil Synchromesh into SOHC transmission
-Jon
Old Mar 24, 2005 | 11:11 AM
redzcstandardhatch's Avatar
something different
i use a 50/50 mix of the pennzoil synchro mesh stuff and Mobil Delvac 15w30 diesel truck oil.
works GREAT.
used to use straight GM synchromesh. worked pretty good.
Old Mar 24, 2005 | 11:25 AM
RCautoworks's Avatar
Default Re: (redzcstandardhatch)
Unless you are low on fluid, the only thing this does is hide the real problem, it won't be a permanent fix, its just covering it up.
Old Mar 24, 2005 | 11:30 AM
92integra_gs's Avatar
Default Re: GM Sychro mesh !!!!!!!!!!!!! IT does work try it for yourself (CRX-Fluffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy &raquo;</TD></TR><TR><TD CLASS="quote">Could use this stuff as well.
-Jon </TD></TR></TABLE>
heard its the same formula as GM except just a different packaging...
Old Mar 24, 2005 | 11:41 AM
EFB16ACRX
Guest
Posts: n/a
Default Re: GM Sychro mesh !!!!!!!!!!!!! IT does work try it for yourself (92integra_gs)
i got pretty pissed when i spent the $ to put this stuff in. My trans went BOOM the next day. Not related to the fluid though, I highly reccomend it
Old Mar 24, 2005 | 11:44 AM
.DOHCebag.'s Avatar
unless your tranny is grinding, i believe this actually causes some wear. on a newly rebuilt tranny, or one in good condition, i would use oem spec.
Old Mar 24, 2005 | 12:56 PM
LSVTEC 91 Civic's Avatar
Banned
Worked better than straight Synchromesh?
For some reason I can't find the Pennzoil stuff here in NC...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">i use a 50/50 mix of the pennzoil synchro mesh stuff and Mobil Delvac 15w30 diesel truck oil.
works GREAT.
used to use straight GM synchromesh. worked pretty good. </TD></TR></TABLE>
Modified by LSVTEC 91 Civic at 5:15 PM 3/24/2005
Old Mar 24, 2005 | 01:04 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: (LSVTEC 91 Civic)
i get the pennzoil syncromesh at autozone for$4.99 a quart.
EJ2-Fluffy's Avatar
Default Re: (recluse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by recluse &raquo;</TD></TR><TR><TD CLASS="quote">unless your tranny is grinding, i believe this actually causes some wear. on a newly rebuilt tranny, or one in good condition, i would use oem spec.</TD></TR></TABLE>
Could you explain why? Its a superior lubricant compared to conventional oils. Hence the cost.
Jon
Old Mar 24, 2005 | 03:03 PM
crxtreme89h's Avatar
Let us know how your tranny shifts after you put 20K on the new stuff. Then I will consider it. Sorry, just like to stick to what has worked in the past until I have long term proof.
Old Mar 25, 2005 | 07:48 AM
90HFCrX's Avatar
i would never put 20k on my tranny without changing the fluid regardless of what i put in my tranny. I race hard period!! so i gotta take care of my stuff i usually change my tranny fluid like everyother oil change. I turely believe this why my tranny has lasted me so long
Old Mar 25, 2005 | 09:07 AM
nautica_t's Avatar
Default Re: (90HFCrX)
definitely would have to vouch for this fluid, only 2 gm product i use are the synchromesh fluid and the penetrating fluid.
Old Mar 25, 2005 | 11:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90HFCrX &raquo;</TD></TR><TR><TD CLASS="quote">i would never put 20k on my tranny without changing the fluid regardless of what i put in my tranny. I race hard period!! so i gotta take care of my stuff i usually change my tranny fluid like everyother oil change. I turely believe this why my tranny has lasted me so long </TD></TR></TABLE>
Sorry, I didn't mean 20K on one fluid change. I meant 20k total on the GM syncromesh. Change it as many times as you'd like.
Old Mar 25, 2005 | 01:37 PM
FairlightRacing's Avatar
Default Re: (crxtreme89h)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">
One guy(1) approaches another guy(2) who has a dog standing near him.
Guy (1) "Does your dog bite?"
Guy (2) "No my dog does not bite?"
(guy (1) reaches down to pet dog and dog bites him)
Guy (1) "Ouch" he looks at guy (2) "I though you said your dog does not bite!"
Guy (2) "That's not my dog"</TD></TR></TABLE>
Pink Panther! This was the funniest part of the whole movie series. My dad and I still say this from time to time and laugh about it.
RS'R'
Jan 3, 2007 05:44 PM
1990hondaHF
34
Aug 25, 2005 06:59 AM
B bOy CrAyOn
Welding / Fabrication
13
Jun 2, 2005 09:25 PM
endlessdv
May 29, 2004 10:35 PM
ericlee303
Apr 21, 2004 03:07 PM
