brake noise
Old Mar 24, 2005 | 05:59 AM
superburner2's Avatar
Default brake noise
recently ive noticed a rythmic brake scraping noise when i lightly apply my brakes coming from the drivers side brake.
i removed the wheel to inspect, and everything looks fine. rotor is clean. lots of pad left. what can cause this noise. it only occurs when i slightly apply the brakes, and disappears when i apply more breaking power. there is one scrape per wheel revolution.
the only thing i can think off is the rotor guard might be getting in the way somehow...
Old Mar 24, 2005 | 10:41 AM
SuperSlow's Avatar
Default Re: brake noise (superburner2)
scraping? If you look at the rotor, is there uneven wear on it, or a patch of rust? Get it resurfaced. Otherwise, look for something stuck on your wheel.
Old Mar 24, 2005 | 07:12 PM
i20ar's Avatar
i had that and currently have it... ive just bean lazy but you shoud try taking off the break pad and putting sum anti-sqeek or anti-vibration substance on the back of the pad and between the points where all metal touches... exept for the part where the pad touches the rotor.. yoru could get that stuff at autozone for like a buck tell them yoru problem they'll help you out too
Old Mar 28, 2005 | 05:05 AM
Default Re: brake noise (14aZnS)
i took the pads out this weekend, cleaned it all up, checked the rotors and put it all back together. things were pretty dirty in there. the noise is now gone. let's hope it stays that way.
Thanks.
hpilot03
Suspension & Brakes
11
Sep 7, 2015 10:26 AM
JayBinNyC88
Honda Civic (2006 - 2015)
Jul 24, 2007 09:33 AM
pcguy760
Apr 8, 2007 03:52 PM
95Integura
May 3, 2006 12:55 PM
RolioPolio
Jun 29, 2002 01:38 AM
