F series vs. H series
Old Mar 24, 2005 | 05:43 AM
703_Sleeper's Avatar
Default F series vs. H series
I have a 92 prelude with a F22B motor swap. The swap came with the car. My question is my starter went bad and i wasn't sure if the starter for the H series was the same as the F series and if they are different where can i find an F22B starter because they were only made in Japan. I'm pretty sure the F series single over head cam vtec motor doesn't match up but i'm not 100%.
Old Mar 24, 2005 | 07:00 AM
md23vtec's Avatar
Default Re: F series vs. H series (703_Sleeper)
The starters are interchangible
Old Mar 24, 2005 | 07:02 AM
Default Re: F series vs. H series (md23vtec)
kool anyone else agree? Also my Alternator is going bad as well. Are those interchangeable.
Old Mar 24, 2005 | 08:39 AM
prelittlelude's Avatar
the starters are inerchangeable and so should the alternator. the only thing is some F series use an alternator belt with less ribs than the hs eries, so worst case you would have to swap the pulleys from your h alternator to the F. shouldn't be to hard
Old Mar 24, 2005 | 09:37 AM
ViZ's Avatar
ViZ
i have both items left over from my motor swap if your interested.
Old Mar 24, 2005 | 12:30 PM
iCe_2x's Avatar
Yeah, Both are interchangeable I beleive.
Old Mar 26, 2005 | 03:33 AM
Default Re: (iCe_2x)
anyone else, bump.
Old Mar 26, 2005 | 03:45 AM
Dougs96SI's Avatar
Default Re: (703_Sleeper)
Why do you need more answers when four people have told you that it will fit. Ill be the fifth and agree with all of the above...It Fits.
Old Mar 26, 2005 | 06:08 AM
Drag-Accord's Avatar
Default Re: (Dougs96SI)
yes both are interchangeable. And if you ever wanna ditch your AC, it's kind of a problem. They never made an H22 w/o AC. So i found that the f22 non-ac belt will fit but the alternator is pulled all the way out. I think there is another belt that fits perfect but i can't remember what it is. The f22 belt works for a couple of months and then goes bad because it can't be tensioned very well, but it works.
Old Mar 26, 2005 | 10:31 PM
Default Re: (Drag-Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">Why do you need more answers when four people have told you that it will fit. Ill be the fifth and agree with all of the above...It Fits.</TD></TR></TABLE>
Because they all didn't seem 100%. They said, I believe it fits and it should fit. Not, I'm positive it fits. But I'm convinced in any since that it fits and i just picked one up for 20 bucks on ebay so it wont be that bad of a loss if it doesn't fit. I just wanted to be positive.
Old Apr 12, 2005 | 06:49 AM
Good news i did the install yesterday and everything works 100% thanks guys!
EGhachiback
Oct 10, 2012 08:23 PM
mayfly
Jul 22, 2010 01:09 PM
redcivic44
Mar 1, 2006 07:32 AM
Audipwr1
May 14, 2003 08:13 AM
