Can a JDM ITR cluster (OBD2) work with a 95 Integra (OBD1)?
actually the way to do this with the best results is to swap the ITR Gauges and CF Bezel into your Stock 95 Cluster.
While changing the green film will make the gauges work properly, the lights that come up will still be wrong. IE.. seatbelt light, door open, ABS, etc...
swapping the rear white housing and green film will solve the problem.
Its not that hard. The cluster bolts right in. I have a 99 JDM type r one in my 95 teg. It was a simple plug and play swap, no problems at all. Only downside is that you will have to learn the conversion between kilometers and miles per hour.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_cars »</TD></TR><TR><TD CLASS="quote">actually the way to do this with the best results is to swap the ITR Gauges and CF Bezel into your Stock 95 Cluster.
Don't forget to swap in the 95 right side icon clusters to your CF bezel. That is why your lights lit up wrong. It's much easier to swap the gauges than the film, since you are already unscrewing them anyways to change films.
</TD></TR></TABLE>Don't forget to swap in the 95 right side icon clusters to your CF bezel. That is why your lights lit up wrong. It's much easier to swap the gauges than the film, since you are already unscrewing them anyways to change films.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oh-k »</TD></TR><TR><TD CLASS="quote">becareful i broke my cf cover while doing it..</TD></TR></TABLE>
Dont forget the 3 screws sunk in in the back there inbetween each large guage.
thats how most people break their bezel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecluder97 »</TD></TR><TR><TD CLASS="quote">
thats how most people break their bezel.</TD></TR></TABLE>
haha... yup every forgets these, then try to rip apart their cluster in the process breaking it.
Yup make sure you take out the screws and be careful taking it apart!
oops! too late.....
oops! too late.....
ok well i guess it depends on what JDM itr cluster you get ...
i just got him yesturday and it works fine on OBD1 car and doesnt work on OBD2 ....
JDMITRTURBO
Aug 8, 2006 05:05 AM
