brake upgrade (mc/bb related)
Old Mar 24, 2005 | 01:56 AM
eda6's Avatar
Default brake upgrade (mc/bb related)
Looking for something to do this weekend. Planned on a brake upgrade.
Currently have SiR knuckles with DA rotors/calipers on all corners, 4040 valve, and 88 dx bb/mc.
Which setup will produce more stopping power?
88 dx booster with one of the following mcs (89 accord lxi, 89 prelude, or 91 civic ex) or the DA non abs bb/mc?
If you think the DA setup will work better please explain why. I need a good reason to swap out a booster that works perfectly.
Thanks to everyone who participates.
Old Mar 24, 2005 | 07:25 AM
Crx Jimmy's Avatar
Default Re: brake upgrade (eda6)
the integra m/c is 15/16 just use the biggest one, i really dont think you need a bigger one i have the same setup i didnt see a difference when i swapped, my buddy was running nsx caliprs with the stock m/c and it was fine
Old Mar 24, 2005 | 07:13 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">the integra m/c is 15/16 just use the biggest one</TD></TR></TABLE>
The 89 accord lxi, 89 prelude, and 91 ex all use 15/16" master cylinders.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">i really dont think you need a bigger one i have the same setup i didnt see a difference when i swapped, my buddy was running nsx caliprs with the stock m/c and it was fine </TD></TR></TABLE>
yep...the brakes are fine, but i think they could be better. Is it possible that you didn't notice a difference because your booster was undersized after you installed a larger mc?
I noticed the DA booster was slightly larger than the civic booster. I'm thinking the DA booster has a larger diaphragm since the black canister is bigger. Can anyone confirm?
which setup will actuate the mc pistons with more force when i apply the brakes? DA bb/mc or ED brake booster with 15/16" mc
Old Mar 25, 2005 | 05:32 AM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">which setup will actuate the mc pistons with more force when i apply the brakes? DA bb/mc or ED brake booster with 15/16" mc
Can anyone answer this question?
Old Mar 25, 2005 | 05:47 AM
mike-y's Avatar
the larger booster will provide more brake assist/brake force when you push the pedal, provided MC's are the same size.
Old Mar 25, 2005 | 08:07 AM
eda6's Avatar
Default Re: brake upgrade (mike-y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y &raquo;</TD></TR><TR><TD CLASS="quote">the larger booster will provide more brake assist/brake force when you push the pedal, provided MC's are the same size.</TD></TR></TABLE>
Thank you that's what i thought.
sedrohatchstyle
16
Aug 21, 2011 06:00 PM
sohcrx91331
Sep 30, 2009 02:02 PM
gunnerman
Oct 19, 2007 08:33 PM
kess
Apr 2, 2005 10:17 PM
E-lude78
Jun 13, 2002 11:46 AM
