Door hinge is broken... any suggestions?
jb weld wont do it , i think jb weld sucks my left nut cause i tried using it to weld my seat pan back toghether and it broke...then i tried welding my catalac converter..and it broke. guess its not ment for heavy duty stuff.
Dont just pull out the pin and call it a day I tried that and the door wont stay open for anything.....pull the pin and get it welded then put the pin back in best way to so it and it will be back o normal you can even sand down the weld nice and flat looking and paint over it so it wont rust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WuShu »</TD></TR><TR><TD CLASS="quote">pull the pin holding it in, hammer it as smooth as you can get it, weld it. easy fix. </TD></TR></TABLE>
hammer what? weld what? can you post some pics? that would be helpful...this popping noise must go away....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote">jb weld wont do it , i think jb weld sucks my left nut cause i tried using it to weld my seat pan back toghether and it broke...then i tried welding my catalac converter..and it broke. guess its not ment for heavy duty stuff.</TD></TR></TABLE>
Depends on where you use it and how you mix it, I have used it on an exhaust for a quick fix, well it last about 2 years. Also used it on my itb's and it worked. You always want to try to put something behind it though for added stability.
Anyways, my Dads 1990 hatch has the same problem, I'm gonna weld it for him.
Needs to be About 20% Cooler
my door broke like that on my sedan.
welded it ...........................................broke
bolted a plate over it / welded it...........broke
cut out a plate and welded it again.......broke
finaly had to cut a section out of a junker and welded the whole thing in the now foot tall hole. and it's working so far.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster »</TD></TR><TR><TD CLASS="quote">my door broke like that on my sedan.
Who welded it, maybe they did not get good penetration.
some guy at my dad's work. he is a profesional welder that makes trusses and platforms for stages and 100+ tons anamatronic figgures (like disiny land cariters)
so he is more than qualified but he said it waqs very diffucult to weld sheet metal.
that piece takes a huge beating.
I ment hammer the piece around the hinge back smooth, if its smooth you dont need to hammer anything, then just weld the little hinge back onto the car to strengthen it. From the pic it looks fairly rusted so im not sure how well itll hold.
Ofcourse it also depends on how many times your door swings open and how much abuse it takes. If its constantly being pulled and its a little rusted then its going to rip right out.
The last resort would definitely be to cut the piece out and weld in a new one like DieMaster said, it really all depends on how bad the piece is. If the piece is rusted to hell welding isnt going to do it much good.
someone should fab up a few plates with a slit just open enough to let the part closest to the door through then weld the back to the part that always damn breaks.then you could just weld the plate and use a couple screws and grind them back. I hate the damn pop, and thats what im going to do.I just needto find a way to get it on around the little silver piece that comes from the broke *** piece.Damn japanese planned this and i know it. Anyone have an si-r or ukdm crx whose doors pop?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXSiSage »</TD></TR><TR><TD CLASS="quote">someone should fab up a few plates </TD></TR></TABLE>
If people want these, IM me and I will fab something up. Welding probably would be required, although if I can make them a screw in deal I will.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trublu619 »</TD></TR><TR><TD CLASS="quote">I riveted a plate on mine. I will post pics tommorow.
please do
</TD></TR></TABLE>please do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilentWrath »</TD></TR><TR><TD CLASS="quote">
please do</TD></TR></TABLE>
Same here
Same here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">although if I can make them a screw in deal I will.</TD></TR></TABLE>
i know it sounds kinda getto but u could use those drywall screews that have the springloaded "backing" so u drill a 3/8 hole, insert it,the springs pop out and u tighten down.
I wanna see!
</TD></TR></TABLE>I wanna see!
i know it sounds kinda getto but u could use those drywall screews that have the springloaded "backing" so u drill a 3/8 hole, insert it,the springs pop out and u tighten down.</TD></TR></TABLE>
Screws are not a problem, I just got a welder so I would weld mine. If people wanted to screw it in, I could make it like that. But right now only 1 person IM'd me and he never emailed me back.
...There has got to be somebody who welded theirs or something.
