390cc injectors?
can i use injectors from a dsm auto turbod car on my homemade turbo setup? i only plan on pushing 8 psi on my mini me, are those good enough? i figurei can find them easier and cheaper than 450s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx »</TD></TR><TR><TD CLASS="quote">390ccs should be enough for 8psi.</TD></TR></TABLE>
psi means nothing....What turbo are you gonna use? 14b? t25?
Modified by GoFast2und at 9:12 AM 3/24/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoFast2und »</TD></TR><TR><TD CLASS="quote">
Modified by GoFast2und at 9:12 AM 3/24/2005</TD></TR></TABLE>
Actually, PSI does have some (not much, but its what he gave us to work with) meaning. Nobody is going to use a giant turbo to push only 8psi.
why is it that psi does not have much to do with injector size? i'm not being a smart *** i would like to know. psi would be caused by force expelled by the turbo and the restience of the intake track to consume that air right? so what would be the difference between a say t25 and a t66?
because a t25 and a 60-1 are not making the same amout of power at 8psi....so if one is making 220whp and the other is making 275whp---390 injectors mite be enough for one but not for the other....
ok so i can use 390cc? the t3 i have seems really small for some reason, its off a chrysler. this car is my daily driver , idrive it long distances for work so i dont plan on anything over 10 psi, so they sh ould work right?
on a turbo that small you should be fine with your minime setup. Here are a few HP numbers to ive you an idea of how much power each injector will support. You can get more if you raise your fuel pressure slightly. But these numbers are based off of 43-45 PSI of fuel pressure.
345cc 200-220 HP
390cc 220-260 HP
450cc 260-310 HP
345cc 200-220 HP
390cc 220-260 HP
450cc 260-310 HP
losder riper
Jul 9, 2004 09:49 AM
