im buying a koyo aluminum radiator for my 00 gsr
What is difference between showa and denso?? The reason im replacing radiator is i have a hole in my radiator. Will the oem fans work with the koyo? Anyone have koyo radiator
showa makes radiators and condensers for honda. Denso makes comresssors, dryers and such for honda. Is the koyo a direct replacement? How many rows?
its a direct fit. i wanna make sure my ac fans will not have fitment issue with the koyo. i know for sure the fluidyne radiator will have fitment issues with the ac fan driver side fan
Oh, Showa and denso radiators........They're pretty much 2 different companies that supplied radiators to Honda, no difference in performance. Only thing I've noticed is the radiator fan shrouds mount up differently between the two makers. AC fan fits fine on both, just not the radiator fan.
I think others have shaved down the shrouds but if you want that Koyo Rad, its not much more to get slim fans.
i actually got the fluidyne radiator with fal fans slim on the ac side.Will i be ok on the radiator fan?
I bought a Koyo and the difference in denso and showa is if you have a DC2 or DC4 I belive. If Im not mistaken the radiator mounts are different and I know that the fan mounts are different.
Easy way to find if you need to know which one to buy is if you still have your factory rad. it should say if its a denso or showa.
cn_bb
Aug 9, 2012 11:00 AM
Pnoyej6
May 21, 2005 02:45 PM
