90-93 cluster pinout
can someone hook me up with a ls cluster diagram from a 90-93 cause i got one and wanted to retrofit it to my crx and no one seems to have it so i came to you guys. help me out please!
Modified by Gumbey75 at 10:42 PM 3/23/2005
Here you are:
PIN Wire Color Wire Function
A1 Yellow/Red Seat Belt Reminder Light
A2 Green/Red Parking Brake Switch Light
A3 Green/Black Hatch Open Indicator Light
A4 Green/Red Low Fuel Indicator Light
A5 Yellow/White Fuel Gauge
A6 Yellow/Red ECM, Trans Control, Moduel TCM, Cruise Unit, VSS
A7 Red Gauge Lights, Dash Light Dim
A8 Empty
A9 Red/Black Gauge Lights
A10 Green/Yellow Right Turn Signal Indicator
B1 Green/Blue Left Turn Signal Indicator
B2 Red/Blue High Beam Indicator
B3 Blue/Red ABS Indicator Light
B4 Blue Tachometer
B5 Green/Red Door Open Indicator Light
B6 Yellow/Green Engine Coolant Temp Gauge
B7 Black Ground
B8 Yellow Ignition Power
B9 Green/Orange Malfunction Indicator (Ck Eng.) Light
B10 Black/Yellow Charging Sysem
B11 White/Blue Charging System (Battery) Light
B12 Yellow/Red Low Engine Oil Pressure Light
C1 Red Cruise Control Unit
C2 Red/Black Gauge Lights - Cruise Control Dimming Circuit
C3 Empty
C4 Empty
C5 Black Cruise Control Ground
C6 Empty
C7 Yellow Ignition Power for Cruise Control Unit
A8 Empty
B4 Blue Tachometer
B7 Black Ground
C3 Empty
C4 Empty
C6 Empty
vtecn8ive
27
Nov 4, 2007 05:41 AM
JdM_RACeR07
Aug 20, 2006 07:01 PM
WWDTrackRacer
Jan 11, 2006 07:08 PM
