no start when HOT ??????
Car is a 90 civic EX Auto, it will not start when hot, can start when cold , park car come back in 30 min. car will not start, replaced the Main relay did not help could
it be the Starter??
Thanks for any help Richard.
it be the Starter??
Check the coil. i had the same problem with my 95 b16 4dr. If the coil is in the disributor i have heard a hundred times it was the coil. They tend to over heat and shut off. Just tap the cap and go MSD external coil. i got my kit for like fifty buck at a parts store. Hope this helps!
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Was it really the coil? because all this time i've heard that its the ICM that goes bad when it heats up and then doesn't let the car start.
If its the ICM then you may as well just buy a new dizzy, the coil can be had for about fifty bucks last time I checked. Get a multimeter and test them!
aaabha
Jul 15, 2010 01:17 PM
