Do I need a camber kit?
Old Mar 23, 2005 | 05:58 PM
saigon1965's Avatar
Default Do I need a camber kit?
I have an 00 coupe with Eibach Sportline springs with OEM shocks, it's rolling on 15" wheels with 195/55/15 tires. Do I need a camber kit or not?
Old Mar 23, 2005 | 06:09 PM
AutoXer's Avatar
Default Re: Do I need a camber kit? (saigon1965)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saigon1965 &raquo;</TD></TR><TR><TD CLASS="quote">I have an 00 coupe with Eibach Sportline springs with OEM shocks, it's rolling on 15" wheels with 195/55/15 tires. Do I need a camber kit or not? </TD></TR></TABLE>
No, but you need an alignment. Set your toe to zero; toe wears tires, not camber.
Old Mar 23, 2005 | 06:10 PM
dohcVTECeg2's Avatar
Default Re: Do I need a camber kit? (EX_AutoXer)
it wouldnt hurt
Old Mar 23, 2005 | 09:38 PM
AutoXer's Avatar
Default Re: Do I need a camber kit? (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">it wouldnt hurt</TD></TR></TABLE>
Yes, it can hurt your wallet. Also, some of the cheaper camber kits can poke through the shock towers, or come loose (ruining your alingment) and cord your tires.
If you lower your car, get an alignment, and for most cases you will be fine.
Old Mar 23, 2005 | 09:39 PM
Luserkid's Avatar
How low is your drop? Do what EX_Autoxer said and take it to an alignment shop. See what they can do if your camber is all off get an adjustible upper control arm.
Old Mar 23, 2005 | 09:43 PM
Kyles ej1's Avatar
Default Re: Do I need a camber kit? (Luserkid)
dont the sportlines only drop u like 1.5"
Old Mar 23, 2005 | 10:24 PM
jeffk182's Avatar
Once u rip apart ur suspension, you need an alignment...
Old Mar 24, 2005 | 06:48 AM
JayDM_EK9's Avatar
if u dont wanna make ur tires bald then i perfer getting the camber kit
Old Mar 24, 2005 | 04:59 PM
saigon1965's Avatar
Default Re: Do I need a camber kit? (I_Love_EK)
Sportline lowers around 2.25". It's been aligned since the springs install. Just don't want to go though tires if I can do something about it.
Old Mar 24, 2005 | 05:04 PM
EVIL Hx Coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saigon1965 &raquo;</TD></TR><TR><TD CLASS="quote">Sportline lowers around 2.25". It's been aligned since the springs install. Just don't want to go though tires if I can do something about it.</TD></TR></TABLE>
Take it to a place that aligns lowered cars... They know what to do to make your tires wear even...
I've done the regular peb boys alignment and tires still got camber wear... I took it to this place called weber (they deal with modified suspensions) and my tires all wear evenly now.
Old Mar 26, 2005 | 07:41 PM
saigon1965's Avatar
Default Re: Do I need a camber kit? (EVIL Hx Coupe)
Thanks everybody.
Old Mar 26, 2005 | 07:59 PM
Ls_V_TurboSi's Avatar
100-150 dollar camber kit is much cheaper than eating up your tires.. I would suggest you get one...
Old Mar 26, 2005 | 08:04 PM
EK k kay's Avatar
Default Re: Do I need a camber kit? (Ls_V_TurboSi)
Get an alignment first. Then if you see uneven wear coming along buy a camber kit. My car has no fender to tire gap and I get no uneven wear on my stock michelins which are **** for treadwear. Don't waste money on something that you might not even need.
d17civic
Honda Civic (2001 - 2005)
Aug 21, 2008 05:32 PM
Weapon X
Mar 26, 2006 08:30 PM
athbaseball23
Suspension & Brakes
Mar 4, 2006 01:24 AM
D17A2~VTEC
Suspension & Brakes
Feb 13, 2006 11:39 PM
SOHC_MShue
Jun 9, 2003 11:03 PM
