Cruise Control Doesn't work?
I just bought a 95 GS-R it has 90,000 mi on it and the cruise control doesn't work.
I couldnt find a fuse for it to see if it was blown. Does anyone know what is wrong with it????
Give a better description as to what is not working and what it is doing. Does the actuator move, check the free play on the cable. You could also check the brake and clutch switches. There are a ton of thinks listed in the Helms manual. If you need anything let me know, i have 2 full cruise control systems collecting dust.
my cruise control didn't work and it ended up being the switch, i pulled the button out and it turned out to be the plastic piece connected to the spring that engagaes the switch, superglued that bitch back together and it works everytime now.....
KDoGx504
Dec 17, 2005 08:52 PM
ophdehEEzY
Jun 26, 2003 05:12 AM
