crooked ass steering wheel
Old Mar 23, 2005 | 05:19 PM
jaycetan's Avatar
Default crooked *** steering wheel
i have a crooked steering wheel. not just a lil bit but its very noticable. i know my alignment is bad but it doesnt seem like thats it. could it be the fact that the steering wheel was just put on incorrectly?
Old Mar 23, 2005 | 05:20 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: crooked *** steering wheel (jayce'shatch)
What do you mean put on improperly? You have a new steering wheel? When was it put on?
Get an alignment, that will fix the problem for sure.
Old Mar 23, 2005 | 05:21 PM
litterbox's Avatar
Default Re: crooked *** steering wheel (litterbox)
AOL me at eh2andy, I've got some parts that you need.
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
I doubt it, probably car was in a wreck, mine is the same, i took off the wheel, and then tried to get it as straight as I could, then I went to get an alignment
Old Mar 23, 2005 | 09:02 PM
jaycetan's Avatar
bump before bed
Old Mar 23, 2005 | 09:12 PM
Kyles ej1's Avatar
just get the car straight and take off the steering wheel and then put it back on so its straight.
Old Mar 23, 2005 | 10:12 PM
Kendall's Avatar
Get it aligned, and while it's on the alignment rack, get the technician to adjust the tie rods so that the wheel becomes straight.
Old Mar 23, 2005 | 10:46 PM
litterbox's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Get it aligned, and while it's on the alignment rack, get the technician to adjust the tie rods so that the wheel becomes straight.</TD></TR></TABLE>
Do they adjust the inner or outer tie rods to straighten the steering wheel?
Old Mar 23, 2005 | 11:01 PM
Kendall's Avatar
Default Re: (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Do they adjust the inner or outer tie rods to straighten the steering wheel?</TD></TR></TABLE>
Outer, it's how the front toe is set. Turn the steering wheel all to way to one side, and you should be able to see the adjustment nuts.
Old Mar 23, 2005 | 11:07 PM
litterbox's Avatar
Outer, it's how the front toe is set. Turn the steering wheel all to way to one side, and you should be able to see the adjustment nuts.</TD></TR></TABLE>Yes, I knew that they adjust the front toe through the outer tie rods, but what I didn't know was that a crooked steering wheel was caused by way out of spec toe.
Old Mar 24, 2005 | 04:04 AM
EKB18BPR3's Avatar
i work for a dealer as a mechanic and i do alignments, if u get ur alignment done somewhere, they will fix it. they will adjust ur toe, camber, caster. at the same time they adjust ur steering wheel and center it and adjust the wheels to go with it.
Old Mar 24, 2005 | 04:05 AM
EKB18BPR3's Avatar
Default Re: crooked *** steering wheel (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">just get the car straight and take off the steering wheel and then put it back on so its straight.</TD></TR></TABLE>
dont listen to this
Old Mar 24, 2005 | 04:42 AM
AutoXer's Avatar
Default Re: crooked *** steering wheel (98B00STED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED &raquo;</TD></TR><TR><TD CLASS="quote">i work for a dealer as a mechanic and i do alignments, if u get ur alignment done somewhere, they will fix it. they will adjust ur toe, camber, caster. at the same time they adjust ur steering wheel and center it and adjust the wheels to go with it. </TD></TR></TABLE>
Camber and caster are not adjustable on civics from the factory. You can get a camber kit if for some reason you want a special camber setup, but even then you can't adjust caster. The only reason that would be out of spec would be if something is bent.
You can read up on alignments here:
http://www.tirerack.com/tires/...n.jsp
Old Mar 24, 2005 | 05:09 AM
RedDC5's Avatar
Default Re: crooked *** steering wheel (EX_AutoXer)
I thought camber, caster and toe were what they adjusted during an alignment. It doesnt make sense that u cant adjust them, they eventually come out of whack as you drive, wheter it be daily driving or aggressive. I know they sell camber kits, but I thought they were for oversized rims.
Old Mar 24, 2005 | 05:31 AM
AutoXer's Avatar
Default Re: crooked *** steering wheel (4door_ridin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_ridin &raquo;</TD></TR><TR><TD CLASS="quote">I thought camber, caster and toe were what they adjusted during an alignment. It doesnt make sense that u cant adjust them, they eventually come out of whack as you drive, wheter it be daily driving or aggressive. I know they sell camber kits, but I thought they were for oversized rims.</TD></TR></TABLE>
Most cars do not come with adjustments for caster or camber. There's no real reason for it, because for 99% of the cars out there, it's just not needed. The only time they will 'come out of whack' is if you bend something.
One of the ways that you change camber is by lowering, and even then, camber does not need to be adjusted in most cases. You will have more camber, but this shouldn't affect tire wear if the toe is set correctly. Wheel sizes do not have an effect on camber if they are sized properly (maintaining outer diameter by plus sizing).
All of this is explained in greater detail at the link I provided.
Old Mar 25, 2005 | 11:12 PM
jaycetan's Avatar
so how can i make sure they do a good job? how much should it cost? one place told me 200 for all 4. toe camber and caster. some ppl have told me the camber cant be adjusted. what are my other options? is it neccessary?
Old Mar 25, 2005 | 11:38 PM
Kyles ej1's Avatar
for a 4 wheel alingment it should be around 100 at the most. camber and caster cant be adjusted unless u have a kit.
Old Mar 26, 2005 | 11:19 AM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayce’shatch &raquo;</TD></TR><TR><TD CLASS="quote">so how can i make sure they do a good job? how much should it cost? one place told me 200 for all 4. toe camber and caster. some ppl have told me the camber cant be adjusted. what are my other options? is it neccessary?</TD></TR></TABLE>Goddam. Ok, like EX_Autoxer said, caster cannot be adjusted on our cars. Camber can be adjusted ONLY if you have a camber kit, and even then, they'll only do it if you ask them too. TOE is all that can be adjusted on our cars.
I know that Sears charges $59.99 for an alignment (that'll include straightening your steering wheel as well) and they have a good alignment rack. BUT, it's all about the technician you get. If you sit in the waiting room the whole time and then they bring you the before and after spec sheet, you have NO idea if those numbers are accurate. Go back there, and watch him do it.
ForceFed Motorsports
Apr 18, 2006 06:55 AM
zeroluck
Suspension & Brakes
Jan 11, 2006 05:42 PM
b e e
Nov 19, 2004 11:04 PM
