Installing JDM 1pc DA headlights
you may need to rewire the lights go to http://www.g2ic.com that is the place to go for DA cars that is where i go. you should sign up
it's kind of a bitch taking the bumper off and whatnot. I'd check out http://www.g2ic.com, they will have everything you need to know to do the install
yea i look up on g2ic a lot. but there is only a wiring diagram. is there anywhere I can get a full isntalltion? because I think that i am going to have to splice up a lot of wires by looking at the page on g2ic
Ok man you're going to have to take the bumper off:
1. Take out corner lights.
2. Remove the two screws on each side of the bumper cover (in teh wheel well area, front, on the rim of it)
3. Once those are out there's two bolts in each of the holes where the corner lights were. Remove them. Bumper will come right off.
Remove all the bolts for the headlights, and pull them out. You wont need to rewire the corner lights, but you will need new plugs for the headlight and the foglights.
The wiring isn't that hard, there's only three wires on the headlight and two on the foglights. You can figure it out just by looking at them, or by using the diagram on G2IC.
Plug everything in and put the headlights on. Should only take you about half an hour at the most. (:
Jurassic Four
13
Jun 4, 2004 03:14 PM
