technical valve adjustment question
Old Mar 23, 2005 | 01:46 PM
RTW DC2R's Avatar
Default technical valve adjustment question
I know how to do a valve adjustment, but I have a few concerns. I recently installed a new block, and put about 1000 break-in miles on it. Now Im going over everything, flushing fluids, checking tensions, etc. During my valve adjustment, I noticed that my timing belt is pretty loose, enough so that I can actually turn the crank a couple degrees before the cam gears start to move. So naturally what happens is when I try to make the cams TDC for cyl 1, the crank has turned a few degrees past the TDC mark on the lower cover. Does this matter as far as the valve adjustment goes? I dont think it does as long as the cam gears are at TDC when I make the adjustment, right? I think I can just correct the tension on the belt later.
Old Mar 23, 2005 | 01:50 PM
PM-Performance's Avatar
Default Re: technical valve adjustment question (RTW Ryan)
as long as the crank is in the correct position and the cams are also then it should be fine.
Old Mar 23, 2005 | 02:04 PM
RTW DC2R's Avatar
well thats what Im saying...its not lining up perfectly because of the loose belt tension. I can probably play with it a bit and line both up but the belt wont be tight in either direction. I dont think it matters too much as far as the valve adjustment goes as long as the cam gears are at TDC. ehhh.
Old Mar 23, 2005 | 02:18 PM
Padawan's Avatar
Darth ModerVader
Default Re: (RTW Ryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan &raquo;</TD></TR><TR><TD CLASS="quote">I dont think it matters too much as far as the valve adjustment goes as long as the cam gears are at TDC. ehhh. </TD></TR></TABLE>
Correct - for a valve adjustment you're really just worried about the position of the cams. However, I certainly wouldn't wait very long to re-tension that belt if it is indeed as loose as you're describing.
Old Mar 23, 2005 | 04:19 PM
RTW DC2R's Avatar
cool. and yep, I dont plan on even starting it til everything checks out.
Old Mar 23, 2005 | 05:22 PM
Jon D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan &raquo;</TD></TR><TR><TD CLASS="quote">cool. and yep, I dont plan on even starting it til everything checks out. </TD></TR></TABLE>
....i have seen many valves bent by dumbasses who don't wait till everything checks out
Old Mar 23, 2005 | 06:13 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: (Jon D)
As long as the cams are on the base circle
nicknack25
Apr 14, 2014 09:53 PM
SsB_Db8
Sep 4, 2009 03:41 PM
NokStrImpz
Mar 28, 2008 09:10 PM
djhatchtraxxx89
Oct 4, 2006 03:46 PM
