IS REAR SEAT GLUED IN????
push the top half forward like you would to put something in the trunk, there is a clip on one side that you pull out. its a black clip that you pull towards the rear of the car. then after you take the top half off you just unbolt the bottom half you can see the bolts it's very easy man.
yeah it's really easy. for each backrest, there is a clamp along the outside..pull that clamp out (looks like a C). Slide each backrest out. Now you can access the bottom portion of the seat. There should be one bolt connected to the bottom of the car behind the seat. After that's off...just pop the seat up... the seats are secured by clips.
not-a-stang
Mar 5, 2008 10:13 AM
hondacivic4g
Jun 13, 2006 04:12 PM
