Ecu chipping...
I'm planning on doing my first n/a sohc build up. what is a safe rev limit for the stock d16a6 bottom end? after i build it (planning on using eagle endyn rods and endyn rollerwave pistons) what could i set the limiter to?
does anyone know who does ecu re-chipping?
thanks a ton guys. i'm kinda new to this bored so i'm still learning my way around... peace...
Check ou this site....it should have everything you need
http://www.zdyne.com
I do, i offer three different chips for 90-1 Si ecus
also offer other kinds of ecu chipping services
http://www.hyperducktuning.com
hey if you can chip an si ecu then what would you recommend for a d16 motor with a crane cam, i/h/e and a mild port and polish? that will be what my motor has when i've got the components together in about a month... how much would it be for you to chip it and how long would it take for turn around on the ecu? like two weeks or a few days? thanks man... i'm interested.
also where did you get that motor in your current hatch? i love sohc's and that looks like a pretty nice one...
btw my aim name is NaturLidiot hit me up sometime. i'd like to talk to you... peace...
[Modified by 5gencivic, 1:09 AM 1/26/2002]
depends on aggressive the cam will be, soon I am going to offer another program. but depends on which route you will want to go. I offer both DIY kits and stage 2 and 3 where I do the work or you get the ecu. at times much better value.
the d15b (JDM) specs are avalible from most JDM importers they are dirt cheap
please e-mail me
please e-mail me
