oil catch can install..
Old Mar 23, 2005 | 08:44 AM
Boost3d22's Avatar
Default oil catch can install..
i recently bought a oil catch can from ebay, but it didnt come with directions, so i have no idea where the lines go on my 97 turbo prelude..............
Old Mar 23, 2005 | 09:35 AM
Hawkze_2.3's Avatar
Default Re: oil catch can install.. (Boost3d22)
Do some research, there's many different opinions on how to hook it up....especially with a boosted car.
Old Mar 23, 2005 | 10:41 AM
Boost3d22's Avatar
i have searched it and cannot find anything clear to me
Old Mar 23, 2005 | 11:28 AM
sharkcohen's Avatar
Search in the Forced Induction forum, there are a million threads on the subject.
Old Mar 24, 2005 | 12:47 PM
Boost3d22's Avatar
Default Re: oil catch can install.. (sharkcohen)
cant some one tell me where they ran their lines?
Old Mar 24, 2005 | 01:51 PM
sharkcohen's Avatar
I would if I had a turbo, but I don't have a turbo
Proper Positive Crankcase Ventilation can be problematic on a turbo engine. What I'm sure you are finding in the old threads is that no one can seem to agree on what the best solution is. What I would recommend doing is taking a look at how manufacturers set up PCV on factory turbo cars, and imitating that.
Old Mar 24, 2005 | 10:00 PM
dreams190's Avatar
try a manufacturer's website, I know STR has instructions for their products on their site, I dunno if maybe greddy has one or OBX maybe, some company that makes catch cans should have online instructions, if not, try hpoa.org.
Old Mar 24, 2005 | 10:56 PM
precord96's Avatar
Default Re: (dreams190)
Maybe some pics will help. It's in an accord, but with an H22A so it will be the same. Sorry, you have to piece together the 2 pics to see how it's routed.
Old Mar 25, 2005 | 12:39 AM
lude_behavior's Avatar
Default Re: (precord96)
What kind of header is that?
Old Mar 25, 2005 | 04:41 AM
fastfu's Avatar
Default Re: (lude_behavior)
Old Mar 25, 2005 | 05:42 AM
sharkcohen's Avatar
Default Re: (fastfu)
He has a turbo, a regular NA PCV setup won't work properly....
Old Mar 25, 2005 | 09:09 AM
Boost3d22's Avatar
Default Re: (sharkcohen)
yes i have a turbo, i have searched a few different forums and cannot get a strait answer.. i will check the manufact. websites... stupid chinese guys cant give me directions!
Old Mar 25, 2005 | 10:06 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: (Boost3d22)
not trying to jack the thread but do thies catch cans have to be emptied out occasionaly or just left alone?
Old Mar 25, 2005 | 10:15 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastfu &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Wrong
Modified by 90blackcrx at 12:01 PM 3/26/2005
Old Mar 25, 2005 | 10:33 PM
jdmcivicferio's Avatar
Default Re: (90blackcrx)
if you think a turbo catch can and a N/A catch can setup is the same, you have never worked on a car....... turbo car creates intake boost...
and by the way those diagrams are wrong.
The picture with the red valve cover is the correct way to hook up a catch can on a N/A motor.
Old Mar 25, 2005 | 11:27 PM
matix's Avatar
Default Re: (jdmcivicferio)
Search is your freind
Took me 1 search to get this thread read what firedrake says. Thats all you need to know.
https://honda-tech.com/zerothread?id=908466
Old Mar 26, 2005 | 06:51 AM
sharkcohen's Avatar
Default Re: (matix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix &raquo;</TD></TR><TR><TD CLASS="quote">Search is your freind
https://honda-tech.com/zerothread?id=908466</TD></TR></TABLE>
That won't relieve positive crankcase pressure on a turbo engine.
You guys are missing the point. This isn't about how to hook up a catch can so much as it is about running positive crankcase ventilation properly on a turbo engine.
Old Mar 26, 2005 | 07:09 AM
finally someone else knows what there talking about
Old Mar 26, 2005 | 07:58 AM
2lude4u's Avatar
When I was boosted I had an elbow (not the pcv) coming out of the valve cover with the hose going to the catch can, then the hose leaving the catch can I had hook into the pipe just after the air filter but before the compressor wheel. That way the movement of air going past the connection (as it's pulled into the compressor helps pull the air out of the catch can).
If you have it hooked up the way people showed in the diagrams (which work for NA) on a boosted set up it's just going to back things up, maybe casue damage, as the boost pressure prevents the PCV system from functioning properly.
Here's a pic from back in the day when I had a Drag kit, before going custom, and now back to NA. You can see the red hoses going from the valve cover to the catch can (near the battery) the see the hose go underneath the radiator hose to where I tapped it in after the air filter.
Old Mar 26, 2005 | 08:46 AM
fastfu's Avatar
what do you mean wrong its the same design it just means you don't have to buy that specific catch tank
Old Mar 26, 2005 | 09:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">
The picture with the red valve cover is the correct way to hook up a catch can on a N/A motor. </TD></TR></TABLE>
Wrong, I don't think so. That is from ( endyn )http://www.theoldone.com
Yes you could hook it up numerous ways
In the diagram I posted, the first drawing is a system with out a catch can, the second is one installed with a catch can.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastfu &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean wrong its the same design it just means you don't have to buy that specific catch tank</TD></TR></TABLE>
Was that towards me ? I'm not gonna get into the whole pcv thing because its been covered, but in my pic the catch can is hooked directly into the block where the crankcase pressure is releived into. Then its filterd threw the catch can. The one pic with the red vave cover is hooked up to the valve cover not the block. There are about 50 to 100 topics covering this and some go in very deep.
Old Mar 26, 2005 | 02:40 PM
ya well endyn is still wrong,
http://www.hardtail.com/techtips/vacuum-pumps.html
i'll trust small block chevy guys anyday
Old Mar 26, 2005 | 02:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">ya well endyn is still wrong,
i'll trust small block chevy guys anyday </TD></TR></TABLE>
Thats saying a lot on Honda-Tech, endyn a company that builds Honda engines, or a small block chevy site. Its not only endyne either, its a ton of other people on here that agree. More pics of where it should be hooked up to
Old Mar 26, 2005 | 04:15 PM
matix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Thats saying a lot on Honda-Tech, endyn a company that builds Honda engines, or a small block chevy site. Its not only endyne either, its a ton of other people on here that agree. More pics of where it should be hooked up to
image.wtdr/wNjg5MTEzNnM0MTNkZmQzMXk1NDE%3D.jpg[/img]
Arnt those pictures of a b series wich will probably confuse people
Old Mar 26, 2005 | 04:18 PM
Default Re: (matix)
Yes but the blocks are pretty much the same, wanted to get the concept across
