License Plate Light Bulb
Old Mar 23, 2005 | 08:10 AM
GreenTeaLS's Avatar
Default License Plate Light Bulb
Hello Honda-Tech Community, i have 1997 Acura Integra LS Sedan , my license plate (rear) bulbs just went out, i noticed it last night, can someone tell me whats the type of bulb that the license plate needs, Thanks Guys
Old Mar 23, 2005 | 08:22 AM
SiR AuToBoT's Avatar
Default Re: License Plate Light Bulb (CypressGreenLS)
go to autozone, kragen
and ask them they could help you out right there
and get the bulbs at the same time.
Old Mar 23, 2005 | 08:41 AM
JustAnotherG20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CypressGreenLS &raquo;</TD></TR><TR><TD CLASS="quote">Hello Honda-Tech Community, i have 1997 Acura Integra LS Sedan , my license plate (rear) bulbs just went out, i noticed it last night, can someone tell me whats the type of bulb that the license plate needs, Thanks Guys </TD></TR></TABLE>
From the T-I article they should be 168 or 194 (same size, but one is brighter than the other).
Old Mar 23, 2005 | 08:44 AM
95gsrteg's Avatar
Default Re: License Plate Light Bulb (total_noob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by total_noob &raquo;</TD></TR><TR><TD CLASS="quote">
From the T-I article they should be 168 or 194 (same size, but one is brighter than the other).</TD></TR></TABLE>
is it really a 194? the same wedge bulb that goes in the front corner? because i think i took a look and the factory one is a bit bigger in size........but the 194 wedge will fit in there. i just don't know if it'll be brighter or not than the factory one.
Old Jan 15, 2013 | 08:07 AM
SPR876-B18C1's Avatar
so i tired to change my bulb .. but on pulling out the light i realized there was no bulb in it and no connections ..
so im jus wondering now .. after i buy a bulb how do i go about getting the light to work .. i see some wires inside the trunk on the left hand side panel .. is it that i am goin to have to pull off the back bumber and run a connection from that wire im seeing to the licence plate light ..
sounds like alot
Old Jan 15, 2013 | 11:08 AM
G-Weezy's Avatar
The wire goes up through the back plastic panel in the trunk. Remove that panel and you will see a connection plug there.
I wired LED's to that source and fed the line through the same holes the wires are running through. Mounted the LEDS in the brackets.
Old Jan 15, 2013 | 12:59 PM
fcm's Avatar
fcm
Old Fart
Good luck removing anything to do with the licence plate bulbs, bulb lens or bracket.
Spray with a release agent, [MoveIt] before attempting to remove any phillips screw, they will be rusted and you will strip the heads if not real careful.
It is a 168 bulb. [12V 8W]. 94
Old Jan 16, 2013 | 05:58 AM
ok kool was thinking that might be it .. gonna do that asap
already took them out .. with just the phillips
Dekorum
Jan 2, 2014 07:04 AM
PSU
May 1, 2010 01:23 PM
FRESHTEG
Mar 13, 2010 12:36 PM
vtec-adykt
Jan 15, 2006 05:36 AM
dawrenn
May 26, 2005 08:53 AM
