96 EX b16 question
I want to do a b16 swap into my ex and have b16a G1 swap iwas going to do into my crx but crx lives no more. What do ineed to do to put this in to my car any help or links would be great thanks
your going to need rear tranny mount and upper driver side motor mount bracket from the 99-00 si, use your existing wiring harness and injectors from your ex, an obd1 or obd2 dohc vtec distributor.......uh....you'll need a bunch of stuff......if your g1 b16 is a white plug then your gonna have to do a lot of re wiring as many of the plugs are different from obd0 to obd 1 and 2. not to mention you'll have to run a different ecu if your 1st gen b16 swap came with one. your better off selling that swap and getting one that is closer to the year your car is
sladed16y8
Apr 13, 2007 06:56 AM
