price estimate please quote.
Old Mar 23, 2005 | 12:17 AM
idriveadelsol7's Avatar
Default price estimate please quote.
i did a serch.. found these parts. planning to auto manual convert my 94 del so S w/ the d15 series motor. how much do these parts cost? no aftermarket, used parts out of the junkyard or something. appreciate it people. thank you. & are all the D series transmission parts compatible? like the civic/crx?
5 Speed Transmission part list
Flywheel
Shifter
Shift Boot
Flywheel Cover
Manual Intermediate Shaft
Pedal Assembly
Rear Tranny Bracket??? (Rear mount support?)
Upper tranny mount
Shift Linkage
Manual Starter
Manual Center Console with shift boot
Guage Cluster
ECU
Shift ****
Clutch
Clutch Master Cylinder
Slave Cylinder
Shifter Bushings
New Grounding Wire
Additional Parts:
8? 17mm 12 point screws (Flywheel Bolts?)
Manual Stiffener
Modified by unrefined7 at 1:45 AM 3/23/2005
Old Mar 23, 2005 | 12:41 AM
nub.96ek's Avatar
Default Re: price estimate please quote. (unrefined7)
Try a junkyard... I got my friend everthing but the tranny for $75 from a yard...
Old Mar 23, 2005 | 02:11 AM
Junk Ex's Avatar
Most D's from 92-00 can be interchange able but it depends on what parts, but yea trannys can be.
Old Mar 23, 2005 | 02:21 AM
capbyrd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unrefined7 &raquo;</TD></TR><TR><TD CLASS="quote">how much do these parts cost? no aftermarket, used parts out of the junkyard or something. </TD></TR></TABLE>
are you saying that you dont want to use any used parts. if so, and you only want new stuff then you are looking at spending a ton of money
ydoubleonie
Aug 31, 2008 01:03 PM
Jameson
Apr 18, 2005 02:07 PM
keoji
Jul 22, 2004 11:29 PM
Mike_C
Oct 1, 2002 09:20 PM
Fr0m4311
Sep 29, 2002 01:05 PM
