whats wrong?
Old Mar 22, 2005 | 10:53 PM
CivicRaping's Avatar
Default whats wrong?
soemtimes my headlights dont go on and i have to give i a little tap so they come on? what can be loose? can it be the connection to the bulbs are loose?
Old Mar 22, 2005 | 11:11 PM
Magick211's Avatar
Default Re: whats wrong? (CivicRaping)
Where excatly are yo giving a "lil tap" at? That could give you an idea of where the short may be
Old Mar 22, 2005 | 11:25 PM
Default Re: whats wrong? (Magick211)
just the front of the headlight
Old Mar 22, 2005 | 11:56 PM
aaronhume's Avatar
try your headlight plugs, then check the plug inside the steering column that connects to the signal arm (I had a problem there once myself) and then try the three boxes that are grounded (2 on battery side, one is the relays, another is a small plasic rectangular shape that has a ton of black wires coming out of it, and one of those on the other side as well) make sure those are grounded very well. (I had a problem with those once too)
Old Mar 23, 2005 | 07:26 AM
bagpipe goatee's Avatar
yeah, i had the same problem. i couldn't find out what it was, but then i ended finally switching the bulb off another car, and it turned out being the bulb had a bad socket, even though i couldn't visibly see anything wrong.
da_wesmeista
Feb 8, 2010 02:43 PM
soberstan
Oct 19, 2004 04:08 PM
philibuster
Oct 2, 2004 11:08 PM
redEH2
Feb 2, 2004 01:34 PM
Q-OnE
Aug 14, 2002 05:49 PM
