Integra is trippin out... not starting. now no pwr windows or pwr locks!?!
Old Mar 22, 2005 | 10:30 PM
THE GAME IS THICK's Avatar
Default Integra is trippin out... not starting. now no pwr windows or pwr locks!?!
HELP!
For the past two weeks i have been having trouble getting my integra to start. So i check for power to see if there is anything going to it and it showed 12volts. Also the battery is still good (no dim lights all electrical works.. When i turn the key i hear the fuel line turn on but no start, no crank, no nothing. I figure its the starter, and change that. Still doesnt start. I figure its the ignition switch so i replace that and vheck for continuoty (sp?) and it all checked out fine. Lately its been starting some times and sometimes it doesn't. I have already checked all the fuses and they seem to be working fine. There is an autostart on the alarm but i dont think thats the problem, at least thats what the installer told me. I removed the fuses from the boxes to totally remove it from the equation. But now still no start? I then check to see if the window switches and power locks are working and no luck! Also both switches all around the car dont work and power loocks dont work on the passenger side.
Is there a relay that may be bad?
Where would i find it?
What other problems could it be?
Here are some pics of the mess:
Old Mar 23, 2005 | 09:56 AM
Default Re: Integra is trippin out... not starting. now no pwr windows or pwr locks!?! (THE GAME IS THICK)
Old Mar 23, 2005 | 11:13 AM
B20TDC2's Avatar
this maybe a shot in the dark, but have you tried to change your main relay its left of the fuse box with the brown plug. i dont know about the windows and locks but sometimes if its gone bad it will start sometimes and not others . try that and see if it helps
Old Mar 23, 2005 | 05:54 PM
bump for the evening
Old Mar 23, 2005 | 06:16 PM
del_orson's Avatar
I would take the car out of gear and apply the parking brake. next turn the key to the on position, next ,cross the starter power to the little starter wire on the solinoid. If it does not start, check for power. also if it does not start, check your ground wires from motor to rad support, and tranny to frame. let me know how you made out.
Old Mar 24, 2005 | 02:32 PM
oh-k's Avatar
Default Re: Integra is trippin out... not starting. now no pwr windows or pwr locks!?! (del_orson)
i had a similar problem. turned ou tit was my clifford alarm brain. i sent it back to clifford and they gave a new brain with 2 new remotes. after that everything was fine, except i need to reprogram the brain now..
Old Apr 26, 2005 | 03:54 PM
quiksheit's Avatar
Default Re: Integra is trippin out... not starting. now no pwr windows or pwr locks!?! (oh-k)
Hey i have the same problem now. What happened??
vtecdc4
May 10, 2011 11:50 AM
95_B18b1_Teg
Sep 15, 2010 01:28 PM
inline4
May 27, 2005 09:14 PM
rexheadb16a
Jun 4, 2003 05:30 PM
strils
Oct 11, 2001 04:48 AM
