Check Engine Light...wont go off!!!!
I was trying to do some wiring on my 96 prelude when I accidentally let two wires touch. They shorted and burnt the fuse under the hood for the ABS....the ABS light and the check engine light came on on the dash. When I replaced the fuse...The ABS light went out but I cant get the Engine light out. Anyone have any ideas?? could it be another fuse blown?? I have check all that I know of.
heres what ya do:
first, disconnect your battery for 5-10 minutes, put it back on, and start the car. let it idle for a few minutes, then drive around. See if any lights come on. If they do:
Reach under the dash, behind the radio, on the driver side. you'll find a plug with two wires going into it. (blue clip, brown & blue wire I think)
with the ignition off, stick a paperclip into the end of the clip to jump the circuit.
turn the ignition on, but don't start it.
your CE light will come on, turn off, then start flashing a code.
tell us that code.
we'll go from there
tell us that code.
we'll go from there
Thanks for the help everybody....Still havent fixed it yet...school so no time......but that website you told me about was what I needed...thanks again
Danny Sihapanya
Dec 15, 2012 06:45 PM
