is it possible to fix an offset?
Old Mar 22, 2005 | 09:17 PM
danacixem's Avatar
Default is it possible to fix an offset?
I have a set of gram lights on my prelude but it rubs a little be when i hit a bump in the road. The offset is a little off. It is +40mm i need to have +45mm offset so that they dont rub at all.
Is there any way to get them to fit right? Is it pissible to take the rims somewhere and get them shaved a little from inside? I would really like to fix them becuase I love how they look on my car.
Old Mar 23, 2005 | 12:15 PM
Mike_C's Avatar
yes you can do it, no i wouldn't do it.
Old Mar 23, 2005 | 12:47 PM
danacixem's Avatar
Default Re: (Mike C)
why not? even if i can get it to 42mm it would be good so i would only need to shave 2mm. why is it a bad idea??
Old Mar 23, 2005 | 01:00 PM
Mike_C's Avatar
there is a reason volk/rays/whatever made the wheel that thick i would think. they are the wheel engineers, i wouldn't question them. you *should* be fine since you're right, it is just a few millimeters... i just don't mess with drilling/grainding wheels.
Old Mar 23, 2005 | 07:09 PM
ekek888's Avatar
we shave wheels all the time. we shave the hub about 9mm shave the flange and rim about 3mm and race them on circuit. they havent failed us.
rallying would be different. we do not touch them at all.
Old Mar 24, 2005 | 11:30 AM
Green JDM-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">there is a reason volk/rays/whatever made the wheel that thick i would think. they are the wheel engineers, i wouldn't question them. you *should* be fine since you're right, it is just a few millimeters... i just don't mess with drilling/grainding wheels.</TD></TR></TABLE>
You are wrong sir. They made the wheel for that particular offset. I have been running a custom wheel shop for quite some time and we have wheels shaved or drilled all the time. For the type of wheel in question you could shave the wheel, but definitely not more than 5mm. That is the max i would shave a tuner wheel. If you tried to go more, you could compromise the structural integrity of the wheel. If you think you could get away with just shaving 3mm that would be the optimal solution, but i have a feeling that you are probably gonna need all 5mm. Preludes usually take an offesett in the 43-48 range with some exception. If you can give me a little more info on your setup, like your tire size and suspension setup you might be able to keep your wheels intact and change something else.
Old Mar 24, 2005 | 11:52 AM
Mike_C's Avatar
Default Re: (Green JDM-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green JDM-R &raquo;</TD></TR><TR><TD CLASS="quote">You are wrong sir.</TD></TR></TABLE>
then why did you agree with me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">yes you can do it</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green JDM-R &raquo;</TD></TR><TR><TD CLASS="quote">you could shave the wheel, but definitely not more than 5mm.</TD></TR></TABLE>
Modified by Mike C at 5:12 PM 3/24/2005
Old Mar 24, 2005 | 01:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">then why did you agree with me?</TD></TR></TABLE>
Sorry, you are not wrong. You just did not provide any sort of knowledge to back up your opinion except that we should not question anything Volk/Rays does because they are some sort of wheel god. I'm not saying that they don't know what they are doing, but when they make the wheels they don't know which vehicle model some is gonna put it on.
Old Mar 24, 2005 | 03:15 PM
Mike_C's Avatar
i was giving personal opinion
Old Mar 24, 2005 | 09:21 PM
fillup's Avatar
or you could just roll your fenders.
Old Mar 25, 2005 | 04:57 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green JDM-R &raquo;</TD></TR><TR><TD CLASS="quote">... but when they make the wheels they don't know which vehicle model some is gonna put it on.</TD></TR></TABLE>That's true when they cast the wheels, but once they're drilled you have to worry about the thickness below the seat for the lug nut.
05member y0
May 2, 2006 04:43 PM
cappelhans
10
Jan 23, 2006 06:32 AM
electronb16si
Feb 3, 2005 04:09 PM
hybridb18
Apr 20, 2004 12:32 PM
JoeyBallzSI
Oct 20, 2003 03:04 PM
