what's going on with detonation?
Old Mar 22, 2005 | 09:06 PM
scUba-stEve's Avatar
Default what's going on with detonation?
what is actually happening when people say there is detonation? i know it's a bad thing, but what is actually happening? this could be a newbie question...but i would like it answered...thanks.
Old Mar 22, 2005 | 09:37 PM
Default Re: what's going on with detonation? (zer0-psi)
when i get to about the 3k rpm range, i start to hear a ping...i checked the plugs and they're all brown...there is a loss in power also...i know i need to get it tuned, but just wondering if it's detonation even though the plugs are brown and not white...thanks in advance.
Old Mar 22, 2005 | 09:54 PM
asubennett's Avatar
Default Re: what's going on with detonation? (90blackcrx)
What you are experiencing is pre-ignition. You are firing the mixture when the piston is still on it's way up. The reult is your motor wants to start the power stroke when it still hasn't finished it's compression stroke- That motion repeated over and over can put a beating on a piston.
Old Mar 23, 2005 | 07:44 AM
Default Re: what's going on with detonation? (asubennett)
i'm running about 12:1 compression on 92 octane(i used a can of octane booster, just to see if it'll help)...i retard the timing a little, so it's around 13-14 degrees now...so the pinging starts at around 3k for about 100-200 rpms only, and then it goes away...i know it's not safe to be driving the car like this...but it's my only car, and plus i dont smash on it or anything, just drive it to work(about 10 miles) and back home...that's it.
Old Mar 23, 2005 | 08:07 AM
98lsskunk's Avatar
not running enough octane for that kind of compression. you can always go about lowering your compression a little with a thicker headgasket or some pistons with a little less compression, what pistons are you using ctr? or an aftermarket piston?
Old Mar 23, 2005 | 09:36 AM
asubennett's Avatar
Default Re: what's going on with detonation? (98lsskunk)
Instead of octane booster spend $10 on two gallons of Xylene and your octane will be close to 98 if you blend it with 8 gallons of gas
Old Mar 23, 2005 | 09:40 AM
mmuller's Avatar
Mad Scientist
add a little of fuel in that area to see if it helps. back off timing as your last resort.
I see that there is a misunderstanding about pre-ignition and detonation.
https://honda-tech.com/zerothread?id=1180205
Old Mar 23, 2005 | 09:41 AM
lohatch's Avatar
PREIGNTION (PING)
-A/F mixture ignited before spark
-caused by hot spots (carbon particles, plug electrode, sharp edge, running lean, too hot plug range)
DETONATION (KNOCK)
-A/F ignited after spark due to heat and pressure
-burns about 6x faster when this happens
-caused by too much spark advance, too low octane
-occurs under low load/low RPM
Old Mar 23, 2005 | 02:28 PM
asubennett's Avatar
Default Re: what's going on with detonation? (lohatch)
I am confused by your explanation.
You said detonation: air fuel ratio burned after spark.....
What would be there to burn after the mixture has seen a spark?
Pre-Ignition is ussually a result of too high of compression and not enough octane.
Low octane fuel burns easier and high compresion alone can cause pre-ignition. Sort of like a diesel car that ignites fuel off of like 18:1 compression ratios and no spark plug.
Old Mar 23, 2005 | 03:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">I am confused by your explanation.
Low octane fuel burns easier and high compresion alone can cause pre-ignition. Sort of like a diesel car that ignites fuel off of like 18:1 compression ratios and no spark plug.</TD></TR></TABLE>
i think he meant something like, there's left over spark or something in the chamber, that'll spark it self...something like that...i read it somewhere, unless i'm just talking out of my ***...hahahaha.
Old Mar 23, 2005 | 05:23 PM
mmuller's Avatar
Mad Scientist
detonation is end gasses in the chamber self combusting( because of octane, pressure, with the help of a hot spot..whatever)
This happens AFTER the spark plug has ignited the mixture. The ping that you hear are the pressure waves of the multiple flame fronts colliding with each, chamber, piston, etc.
they resonate and create vibration. Kinda like hitting the pistons with a hammer.
Detonation usually breaks things because of the shock.
pre-ignition happens BEFORE the spark plug ignites the mixture, it usually happens close to bottom dead center.
Its created by a hot spot acting like a glow plug. pre- ignition usually melts because of the extreme heat.
An engine Will be lucky enough to see pre-ignition once or twice in its life. You can NOT be pre-igniting all the time..
Pre- ignition gives NO warning.
read the link that i posted above, it has some pretty good info
edit: spelling owns me..
Modified by mmuller at 3:49 PM 3/24/2005
Old Mar 24, 2005 | 01:31 AM
UNKNOWN_MEMBER's Avatar
Default Re: what's going on with detonation? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">detonation is end gasses in the chamber self combusting( because of octane, pressure, with the help of a hot spot..whatever)
Detonatuion usually breaks things because of the shock.
pre-ignition happens BEFORE the spark plug igntes the mixture, it usually happens close to bottom dead center.
An engine wil be lucky enough to see pre-ignition once or twice in its life. You can NOT be pre-igniting all the time..
good explanation
Old Mar 24, 2005 | 08:57 AM
asubennett's Avatar
Default Re: what's going on with detonation? (UNKNOWN_MEMBER)
Agreed, Thanks mmuller
Old Mar 24, 2005 | 11:58 AM
SlothSi's Avatar
Yes, detonation happens after spark. The ping is caused by sharp (very fast) explosion of gasses which cause the engine block to resonate at ~6600Hz. This is a frequency that a knock sesnor would monitor btw. The damage seen in vehicles the experience detonation is due to breakdown of the boundary layer of air that protects piston and clyinder wall against heat. Non-engineers - Look up what a boundary layer is if you want. During normal combustion the boundary layer is not affected because combustion is burn NOT explosion.
Also, because Hp/Cu-in in a Honda is high &gt;1.5 typically, detonation has higher potenial to cause engine damage.
Old Mar 24, 2005 | 12:00 PM
97L-esVeeTeg's Avatar
Default Re: what's going on with detonation? (SlothSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlothSi &raquo;</TD></TR><TR><TD CLASS="quote">Yes, detonation happens after spark. The ping is caused by sharp (very fast) explosion of gasses which cause the engine block to resonate at ~6600Hz. This is a frequency that a knock sesnor would monitor btw. The damage seen in vehicles the experience detonation is due to breakdown of the boundary layer of air that protects piston and clyinder wall against heat. Non-engineers - Look up what a boundary layer is if you want. During normal combustion the boundary layer is not affected because combustion is burn NOT explosion.
One of the best 1st posts i've ever had the pleasure of reading
Old Mar 24, 2005 | 04:36 PM
DonF's Avatar
Default Re: what's going on with detonation? (97L-esVeeTeg)
You need to have your ECU modified to pull pat throttle/ low RPM advance in the area you are getting detonation. Hi vacume low RPM may have over 40 degrees advance, get a chipped/ custom ECU.
Old Mar 24, 2005 | 06:09 PM
vtec y0's Avatar
Default Re: what's going on with detonation? (DonF)
Learned somthing new today on h-t!
Old Mar 24, 2005 | 10:09 PM
asefi944's Avatar
what happens is the fuel is burned before the sparkplug fires, and before the piston moves up. thats when you hear a clapping/or pinging sound. This is bad. Check your ignition timing use higher octane fuel.
Old Mar 25, 2005 | 10:20 AM
GeeReg's Avatar
Default Re: what's going on with detonation? (asefi944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asefi944 &raquo;</TD></TR><TR><TD CLASS="quote">what happens is the fuel is burned before the sparkplug fires, and before the piston moves up. thats when you hear a clapping/or pinging sound. This is bad. Check your ignition timing use higher octane fuel. </TD></TR></TABLE>
The question has been answered.....correctly. Read the thread.
keep it going
Dec 7, 2016 11:10 PM
HellaFab
13
Sep 21, 2011 04:10 PM
sick93sol
Jun 10, 2007 09:17 AM
porter
Oct 18, 2006 11:25 AM
Shark Tank
Nov 4, 2002 11:30 AM
