Will 90-93 integ Lower tie bar fit on an ef civic hatch with 90-93 LCA?
Old Jan 25, 2002 | 04:34 AM
warfa's Avatar
Default Will 90-93 integ Lower tie bar fit on an ef civic hatch with 90-93 LCA?
I did a search of the archives but didn't find anything. Anyways, I'm going to do the rear disc conversion on my civic dx using the trailing arm, rotors and calipers from a 90-93 integ. While i'm doing that, I was hoping i could swap the LCA's too. That way I could fit a lower tie bar under there rather than drilling a hole and stuff. If I swap the LCA's what rear tie bars could I use?
Old Jan 25, 2002 | 07:25 AM
Mugen Dom's Avatar
Default Re: Will 90-93 integ Lower tie bar fit on an ef civic hatch with 90-93 LCA? (warfa)
wut year is ur ef if its 89-91 u can use ur control arm rioninja made a post on how to tap the control arm to make it work with a sway bar the sway bar wont work if u dont get a si brakets though and they dont bolt on cause the frame doesnt have thread in it like the si so either u weld or figure a way to make it work
Old Jan 25, 2002 | 08:20 AM
hardware17's Avatar
Anybody know of some good archives on the brake swap?
Old Jan 25, 2002 | 08:24 AM
Mugen Dom's Avatar
Default Re: Will 90-93 integ Lower tie bar fit on an ef civic hatch with 90-93 LCA? (hardware17)
yeh its called click on SEARCH it works for real
NotoriousCRV
Aug 23, 2010 09:31 AM
joshfor
Jan 11, 2010 07:13 AM
lived dreams
Mar 20, 2009 10:08 PM
OUT OF ORDER ROB
Jun 14, 2006 11:51 PM
vegaskurt
Jun 30, 2005 09:55 AM
