bad sounding idle
Old Mar 22, 2005 | 07:55 PM
mnbv's Avatar
Default bad sounding idle
The idle of my car is pretty crappy sounding. It sounds like ticking or something, its hard to describe. I recently did a bunch of maintainece on it, but I still have left to do the spark plugs. Another thing that my helms manual says to do is to valve work, its a bit over due also. Could eather of these things be the problem, or would it be something else?
Old Mar 22, 2005 | 08:04 PM
r3dh4tch's Avatar
Default Re: bad sounding idle (mnbv)
honda valvetrain is a common noise on higher mileage engines. it's not a big deal, but you should look into getting the clearances back down to where they need to be. if you do that and you've still got noise... sometimes fuel injectors make slight ticking noises.
Old Mar 22, 2005 | 08:05 PM
mnbv's Avatar
Default Re: bad sounding idle (r3dh4tch)
would simply not doing this maintainance effect long term reliabilty?
Old Mar 22, 2005 | 08:06 PM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3dh4tch &raquo;</TD></TR><TR><TD CLASS="quote">honda valvetrain is a common noise on higher mileage engines. it's not a big deal, but you should look into getting the clearances back down to where they need to be. if you do that and you've still got noise... sometimes fuel injectors make slight ticking noises.</TD></TR></TABLE>
Yup, valve clearance, get it checked. I'm also overdue for this service and that ticking from under the valve cover is starting to get to me. guess I'll wait till its a little warmer to do it.
Old Jun 25, 2005 | 08:23 PM
mnbv's Avatar
Default Re: bad sounding idle (HalfAnP)
If I brought the car into a respected shop, how much would it cost to get the valve clearance checked up?
Thanks for the interest.
Old Jun 25, 2005 | 08:36 PM
mnbv's Avatar
should I just bring it up there?
gaby
May 21, 2008 07:18 AM
turbotime
Jul 3, 2006 09:37 PM
Clean.CL
Jan 29, 2005 09:44 AM
n00bs suck
15
Jul 29, 2004 06:47 AM
