Spoiler holes
I know when you take hte gsr spoiler off your left with 6 holes 4 for spoiler and 2 for the
light since i am getting a type r spoiler i was wondering does anyone know or remember what the size for the 2 holes that the type r spoiler will not connect? i assume its the spoiler lights holes. i searched and found sizes but i didnt know which size corresponded to the extra 2 holes thanks guys. and would be putting some little rubber stoppers work? or is there something else i shoudl do to make sure it doesn rust.
alright man try this... you take a thin gauge aluminum and cut it in a rectangle to cover the holes. Make sure you coat the aluminum with a rust preventer. Then, you silicone it in place from underneath. Worked great on my friends teg and you can even paint the aluminum piece with touch-up paint if you want to underneath. Just make sure you don't put on too much silicone so it splooges out the top of the holes too much. If it does though you can just cut it off. Good luck and I hope it works out for you too!
