CRX HF B16a stumbles, Open loop?
Old Mar 22, 2005 | 06:10 PM
acuratech's Avatar
Default CRX HF B16a stumbles, Open loop?
I had a stumble with my b16a under steady, and light throttle conditions. I searched and found out that the O2 sensors can cause this. I unplugged my 02 sensors, and the symptoms are gone, B16a runs perfect. My question is, is it safe to run this B16a open loop until I get my OBD1 P30 swap done. It will probably only be a week or two, but I do not want to run the risk of damaging this B16 I just got in two weeks ago. TIA
Old Mar 22, 2005 | 06:19 PM
520_Motorsports's Avatar
Default Re: CRX HF B16a stumbles, Open loop? (acuratech)
you'll be fine it'll probably just run rich until you get it fixed.
Old Mar 22, 2005 | 06:58 PM
honda06si's Avatar
mine did the same thing same exact problem . i swapped the wires at the pcm for the 2 o2 sensors...problem solved. never ran better
Old Mar 22, 2005 | 07:53 PM
acuratech's Avatar
Default Re: CRX HF B16a stumbles, Open loop? (honda90si)
Good info, I will give that a try tomorrow. I do not like check engine lights, so maybe this will do the trick... Thanks..
FakeJDMEF8
Sep 26, 2005 05:39 PM
acuratech
Mar 22, 2005 06:11 PM
paulzy
11
Mar 9, 2003 09:03 PM
