DPFI to MPFI questions
Old Mar 22, 2005 | 01:46 PM
sIcKvIc's Avatar
Default DPFI to MPFI questions
Was up, does anyone know of and sites that deal with the conversion to MPFI. I bought the wire harness, intake manifold, distributor, and ecu. Hooked everything up and i am still throwing codes for the EACV, IAT, and Crank angle sensor. IF anyone has done this swap drop me a little help please.
Old Mar 22, 2005 | 03:38 PM
bustah49's Avatar
Default Re: DPFI to MPFI questions (sIcKvIc)
DPFI to MPFI Fuel Injector Swap Guide #1
http://www.angelfire.com/d20/h....html
DPFI to MPFI Fuel Injector Swap Guide #2
http://www.geocities.com/teampimports/fuelinj.html
DPFI to MPFI Fuel Injector Swap Guide #3
http://www.geocities.com/c_rexboy/mpfi.html
DPFI to MPFI Fuel Injector Swap Guide #4
http://www.bladesilver.net/crx/
DPFI to MPFI Fuel Injector Swap Guide #5
http://www.fourthgenhatch.com/mpfi.html
Old Mar 22, 2005 | 03:47 PM
slow_rex_will's Avatar
What year, make, and model did you get the wire harness from, because im trying to get one that is uncut from a junk yard, but when you say jdm, they dont know what your talking about?
Old Mar 22, 2005 | 05:37 PM
FalkenSiR's Avatar
Default Re: DPFI to MPFI questions (illwill33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sIcKvIc &raquo;</TD></TR><TR><TD CLASS="quote">Was up, does anyone know of and sites that deal with the conversion to MPFI. I bought the wire harness, intake manifold, distributor, and ecu. Hooked everything up and i am still throwing codes for the EACV, IAT, and Crank angle sensor. IF anyone has done this swap drop me a little help please.</TD></TR></TABLE>
EXACTLY what hapened to me. Switch the plugs of the iat and the iacv and try again. Now, for the dizzy wiring, there are two white wires. Switch them around and try it.
What helped me alot was my dear chiltons with both wiring diagrams for the dpfi and mpfi RIGHT next to each other
Old Mar 23, 2005 | 02:26 PM
sIcKvIc's Avatar
I got my wire harness off of ebay. It came already wired for the swap all you had to do was plug and play. It also came with instructions.
Old Mar 23, 2005 | 02:48 PM
sIcKvIc's Avatar
Default Re: DPFI to MPFI questions (fast88std)
my wire harness came ready to plug and play. the guy i bought it from does the wiring for a side business. I installed the wire harness and plugged everything in and threw 3 codes IAT and the EACV also the Crank angle sensor. I have tried swapping them around and nothing is doing the trick. I am at a complete loss right now. I need up close pictures of this swap if anyone has any.
drowzysleeper
Aug 22, 2005 08:55 PM
EFprojectKid
Aug 22, 2005 04:55 AM
crxtreamz
10
Feb 9, 2005 06:39 PM
civicnightmare
10
Aug 16, 2004 12:05 PM
LsHatch91
Jan 5, 2004 09:09 PM
