I Need a pic of the top of the fuel pump (mounting location)!!!
I am adding a 10gauge power wire to the pump, but I can't get a good visual of where the + wire (yellow/black) mounts to the top of the pump housing. The ground wire is obvious (little screw thing), but I have no idea how to get too the + mounting location.
Any pics, or info would be great!!!!
Bump.
Or can anyone just tell me how the + wire attaches? I just don't want to mess up the wiring, and/or attach the 10gauge wire wrong.
I don't think a grounded + wire at the fuel tank is my kind of pie.
That power wire goes all the way from your main relay to the harness under the back seat (or security trunk) and then from there through the dome and back to the fuel tank.
Look on page two of this PDF:
http://www.honda.co.uk/owner/C...8.pdf
If you want to take the 10awg wire all the way to the pump then you have to drill out the old + wire that mounts to the top of the bracket and goes from there to the pump.. Just make sure you put something around the wire so it doesnt rub through and ground out on the bracket..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant »</TD></TR><TR><TD CLASS="quote">That power wire goes all the way from your main relay to the harness under the back seat (or security trunk) and then from there through the dome and back to the fuel tank.
Umm, I've got that covered. I have a painless wiring relay/fuel pump wiring kit. I just need to know how the + wire connects at the tank.
I'm adding this power wire in addition two the stock wiring, which should give me around 14vs...just like the DSMs...and many other high HP hondas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">If you want to take the 10awg wire all the way to the pump then you have to drill out the old + wire that mounts to the top of the bracket and goes from there to the pump.. Just make sure you put something around the wire so it doesnt rub through and ground out on the bracket..</TD></TR></TABLE>
Damn...so the wiring is hardwired through the tank mount? Well that blows. If I have too drill through it, I'm just gonna run another inline pump. I wan't too keep the stock wiring, and I don't really wanna put a hole through that top mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">Damn...so the wiring is hardwired through the tank mount? Well that blows. If I have too drill through it, I'm just gonna run another inline pump. I wan't too keep the stock wiring, and I don't really wanna put a hole through that top mount. </TD></TR></TABLE>
Well the wiring goes to the top of the bracket and there is a rivet connecting the wire outside the tank to the one inside the tank.. What I did was drilled the rivet out so that the inside and outside wires were gone and ran a wire through the top and jb welded the **** out of it.. Works great and its not that hard to do at all..
ZCcivicBOI
Mar 4, 2006 04:10 PM
FragSyndrome
Apr 7, 2004 01:54 PM
