Can slamming the brakes hurt the half shafts
Old Mar 22, 2005 | 12:24 PM
digitalayon's Avatar
Default Can slamming the brakes hurt the half shafts
On saturday I was on the HWY and then traffic out of nowhere just plain out stopped. I smoked the tires for about 20 feet and it hasn't felt as smooth ever since. And the turns are really shakey.....could this be the half shafts?
Old Mar 22, 2005 | 12:37 PM
The Phil's Avatar
Default Re: Can slamming the brakes hurt the half shafts (digitalayon)
Maybe you warped your rotors? Does the steering wheel vibrate when you're braking?
Old Mar 22, 2005 | 12:57 PM
kevinthefawker's Avatar
your tires are fucked get them balanced or get new ones
Old Mar 22, 2005 | 01:24 PM
matt_in_sd's Avatar
Default Re: Can slamming the brakes hurt the half shafts (xthephilx)
What he said!!
You left so much rubber on the ground that your tires have a flat spot. Rotate tires front to rear might help a little.
Old Mar 22, 2005 | 03:07 PM
iand415's Avatar
Default Re: Can slamming the brakes hurt the half shafts (matt_in_sd)
what everyone said... most likely warped the rotors, especially at highway speeds. and ur tires are probably jacked too, 20 feet is pretty far
Old Mar 22, 2005 | 03:47 PM
Stew Pidasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_in_sd &raquo;</TD></TR><TR><TD CLASS="quote">What he said!!
You left so much rubber on the ground that your tires have a flat spot. Rotate tires front to rear might help a little.</TD></TR></TABLE>
This is probably the case...
Old Mar 22, 2005 | 04:09 PM
Default Re: Can slamming the brakes hurt the half shafts (Stew Pidasso)
I can rotate them, but wouldn't the tires in the rear be the same since the brakes hit there as well. And if it's the rotors, do they get replaced or do they get refinished?
Old Mar 22, 2005 | 04:18 PM
StimpyBoy's Avatar
On most consumer cars, the brakes are biased to lock the fronts before the rears. So no, the rears probably did not lock up. Even if they did, the weight transfer would mean that the fronts have it far worse anyways.
Old Mar 22, 2005 | 06:48 PM
i20ar's Avatar
your rotors could be "re-grinded" or refinished.. i forgot actual turm.. i had it done before works great
Old Mar 22, 2005 | 08:11 PM
momstaxi's Avatar
Default Re: Can slamming the brakes hurt the half shafts (14aZnS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 14aZnS &raquo;</TD></TR><TR><TD CLASS="quote">your rotors could be "re-grinded" or refinished.. i forgot actual turm.. i had it done before works great</TD></TR></TABLE>
the term is turned. as far as the problem it most definatley is the tires. you could rotate them to the rear but problem will still be there, only maybe, less noticable. there is also a good chance you warped your rotors too. that would also have to be looked at...
1998_4dr_gsr
May 17, 2009 04:28 PM
longskate87
Dec 20, 2008 04:18 PM
Torquelessb18
Sep 21, 2008 10:14 AM
OBDII Integra
Sep 1, 2004 08:43 PM
vtec96
Aug 19, 2004 10:56 PM
