Speedometer works part-time...
Old Mar 22, 2005 | 11:43 AM
chris78's Avatar
Default Speedometer works part-time...
My speedometer jumps straight to 20mph when i turn my keys over. It will stay there slightly shaking and sometimes will jump to the correct speed for a matter of several minutes. I had read that this is my speed sensor and so I swapped it out and nothing changed. I then got the idea to disconnect the wire harness from the sensor for s&g's and when I started the car the same thing happened. So without the speed sensor even connected it still jumps up to 20mph and this is without starting the car i will add, just turning the ignition on. Can anyone give me something else to xshoot before i spend big bucks with a mechanic?
Old Mar 22, 2005 | 01:00 PM
fw190bvi's Avatar
Default Re: Speedometer works part-time... (chris78)
my old speedo would complelty stop working for long periods of time....a new speedo unit took car of that (the milege was reset though)
Old Mar 22, 2005 | 11:15 PM
RA042426's Avatar
I'm new to the forums I'm having a weird problem with my speedometer it will work only once in a while when it does work it's accurate it's pretty crazy some times it's saying i go 140mph....I'll take a picture, I posting mainly because i want to know if anyone out there knows where i can get a new speedometer for a 5th gen 95 accord and instructions with pix if possible for disassembly of the dash... Thanks in advance.
Old Mar 23, 2005 | 05:28 AM
Euro R Truco's Avatar
Default Re: (sca2face)
yea i had the same problem this morning. But last night it wasnt like that, i wonder what happened......
Old Mar 23, 2005 | 07:19 AM
jagged4698's Avatar
Have you ever taken the guage cluster out and played with the needles? I made that mistake and mine did the same thing... i had to keep removing the needles and trying to guess as to which position the correct one was for the needle.... If that isn't your case i would say you have a messed up cluster and should just spend the $100 on a used one...
Old Mar 23, 2005 | 08:09 AM
A L I A S's Avatar
Default Re: Speedometer works part-time... (jagged4698)
time to hit up the junk yard
Old Mar 23, 2005 | 09:31 AM
RA042426's Avatar
thanks for replying guys...um to answer a question...I did not mess with the needles or the cluster I'm about too, and don't want to spend a whole lot for a new one and i really don't trust a used one from anywhere <-- has bad experiences with used stuff. lol i believe tasauto.com has it cheap tell me what u guys think?
Old Mar 23, 2005 | 07:36 PM
do you really think they sell those parts on tasauto.com? Been lookin for it and cant seem to find it.
Old Mar 24, 2005 | 06:10 PM
RA042426's Avatar
yes they are there look under interior then click under dash comp.
Old Mar 24, 2005 | 06:59 PM
merinor80's Avatar
I had the same problem where I would turn the car on and the speedometer would read
20 mph. I would run it and it would jump to the correct speed after a couple of minutes. I turn the car off and it the needle would remain and 20 mph. I had installed indiglo lights. I went to a junk yard and bought a used cluster and everything works fine.
Old Mar 25, 2005 | 10:27 PM
RA042426's Avatar
i'm trying to locate a used speedometer if not i'm going to the dealer :-(
Old Mar 26, 2005 | 06:29 AM
rival12's Avatar
yeah speedometer, replace it, i had to.
Old Mar 27, 2005 | 01:48 PM
RA042426's Avatar
Has anyone changed out there speedometer and it still does't work? Could i be the sensor? If so does any one know where it's located on a 95 accord ex also how much which is always the biggest question. Thanks in advance for replying.
Old Jun 6, 2005 | 06:01 PM
i kinda did a lil playin around, i would turn the key onto "ON" and turn it back off and do this 5 times or so. Then the needle drops from 20 to zero and then i start the car, and the speedometer works fine......
Renhard
Sep 11, 2018 08:31 AM
Freckles
Aug 20, 2012 10:30 PM
PGHRich
11
Sep 10, 2010 05:18 PM
blaze.1
Sep 10, 2009 06:24 AM
