d16z6 into my 91 si hatch. which injectors?
Old Mar 22, 2005 | 11:22 AM
kapoosh valve's Avatar
Default d16z6 into my 91 si hatch. which injectors?
ok, so im throwing a d16z6 into my 91 si hatch.
heres my list.
d16z6 longblock with stock d16z6 dizzy
p28 ecu
obd0 --> obd1 conversion harness
now... ive read that the stock d16a6 obd0 injectors can be used, keeping the resistor box. can this be done, even though i will be using the obd1 ecu and dizzy?
if i do convert to the obd1 d16z6 injectors, what will i have to do to make that work? i understand the resistor box can be removed, but what about the plugs (wiring harnesses)? im going to be using my stock 91 si d16a6 engine harness.
thanks
Old Mar 22, 2005 | 12:52 PM
eda6's Avatar
Default Re: d16z6 into my 91 si hatch. which injectors? (kapoosh valve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kapoosh valve &raquo;</TD></TR><TR><TD CLASS="quote">now... ive read that the stock d16a6 obd0 injectors can be used, keeping the resistor box. can this be done, even though i will be using the obd1 ecu and dizzy?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kapoosh valve &raquo;</TD></TR><TR><TD CLASS="quote">if i do convert to the obd1 d16z6 injectors, what will i have to do to make that work? i understand the resistor box can be removed, but what about the plugs (wiring harnesses)? im going to be using my stock 91 si d16a6 engine harness.</TD></TR></TABLE>
depin the resistor box and install an obd1 block off plug. Using a block off plug is the same thing as twisting all the wires together. Very clean and no soldering required. For the plugs-you can solder obd1 clips on or you can depin the harness and install an obd1 injector harness.
Old Mar 22, 2005 | 04:15 PM
yeah, thats kinda what i was askin rexwreck. i was wondering if theres any advantage to using the obd1 injectors.
im not sure what my plans for this motor are but if i install a VAFC or something i was thinking that maybe the obd0 injectors might not work with it or something
Old Mar 22, 2005 | 04:20 PM
Malgerus's Avatar
Default Re: (kapoosh valve)
I would use the Z6 injectors; they're newer, probably in better shape. Justremove the injector resistor. I did it by splicing all the power wires from the injectors into the main power feed that goes into the injector resistor - or you can use that block off plug thing that other guy posted.
Old Mar 22, 2005 | 10:40 PM
what about the plugs? are they the same as the ones used on the si harness?
Old Mar 23, 2005 | 06:51 AM
blackeg's Avatar
the block off plug is a good idea. mine are just soldered together.
Old Mar 27, 2005 | 05:00 PM
how about the alternator? can i use my d16a6 alt?
rev_this
Dec 22, 2007 08:49 PM
Harlowe
20
Dec 2, 2007 10:17 PM
SJcivic
May 3, 2007 09:28 PM
cyipher
May 22, 2006 09:39 PM
preSilude
Nov 30, 2005 06:53 AM
