5 lug conversion
Old Mar 22, 2005 | 11:16 AM
h22teg's Avatar
Default 5 lug conversion
im thinking of doin a 5 lug conversion i heard you have to change your axles but i have an h22a swap so could this work or no?
Old Mar 22, 2005 | 11:58 AM
h22teg's Avatar
Default Re: 5 lug conversion (h22teg)
anyone know anything at ALL?
Old Mar 22, 2005 | 12:40 PM
diM.'s Avatar
which one do you have.
jdm itr 5 lug, jdm ctr 5 lug, or usdm itr
Old Mar 23, 2005 | 01:04 PM
h22teg's Avatar
Default Re: (diM.)
i dont have any yet im just looking in to it
Old Mar 24, 2005 | 08:38 AM
h22teg's Avatar
Default Re: (h22teg)
i find it hard to belive that know one can help me
Old Mar 24, 2005 | 11:04 AM
SilvyIntegra's Avatar
I believe with the ITR 5 lug conversion you need the ITR axles. I looked into doing it myself, but I'm not exactly sure how your H22 works into that.
Old Mar 24, 2005 | 11:49 AM
Spoon ITR's Avatar
Default Re: (SilvyIntegra)
Yes I believe your right, my friend has a 5 lug conversion from an ITR on his CB7 with an H22 in it.
Old Mar 27, 2005 | 10:40 PM
joshonater's Avatar
usdm itr five lug u can use same axles as gsr jdm ctr 5 lug u can use gsr axles jdm itr u need 36mm axles. the jdm itr and ctr dont run abs only the usdm does i dont no if it will work with a h22
Old Mar 28, 2005 | 05:52 AM
Backk InTheDA's Avatar
I hate everything
You don't need new axles, sure they would be nice but, if your going with ITR axles, i believe there the 38mm they are really rare, you can buy them from dealerships, but i think there close to 400 a piece.
But you can just change out the hub, and just get new rotors and such. I thought about doing this myself as well, there was this guy i was chatting with on here about it, he said it costed about a grand just for parts. I'm not sure if he did it himself or if he paid to have it done, either way i'll see if I can find his name and i'll PM you with it.
iTR
Old Mar 28, 2005 | 06:58 AM
IVI's Avatar
IVI
Default Re: 5 lug conversion (iTR2The3rdGen)
with the itr 5-lug you can use any axle. im currently using b16 axles.
if your getting an h22 swap, i "believe" that you would need h22 axles, i am not sure if b-series would fit.
Old Mar 28, 2005 | 07:09 AM
six_speed's Avatar
jdm ctr/usdm itr (5 lug) use 32mm axels (b16/b18 axels)
jdm itr 98-00 (5lug) uses 36mm axels, h22 axels are 36mm
Brian Aumann
Oct 26, 2018 08:28 AM
Boriqua0555
Jun 28, 2007 10:13 AM
jc2801
Jun 7, 2007 10:05 AM
cashkid2004
Oct 1, 2006 06:41 AM
253EK
May 20, 2004 08:08 PM
