BC3+ or BC4
Hi, im running a B16 with DTR pistons ,P&P head, 5anglevalve job,flat valves ,VibrantJ spec4-2-1 header,DIY ITB 48mm, currently running CTR cams, does i can run BC4 on mi set up or you recomend BC3+, im reving it to 9k so i can take advantage of the 4's but clearences(piston to valve ) and 3+ dont make power over 7900 if im correct, what should i do???Can someone tell me?
Munkyw3rkz.webs.com
the BC4's will carry power higher then the +3's. they start to fall off abotu 8200 i think and the BC4's keep claiming..depending on your set up...i have a set of BC4's if interested
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snoflake Tizzle »</TD></TR><TR><TD CLASS="quote">the BC4's will carry power higher then the +3's.</TD></TR></TABLE>
the 4's are too big for the 16. i'd say stick with the 3+'s. they will still pull up high with its short storke & the ITB's. what's your c.r.? i'd assume if you used a set of 4's in the 16, you'll have to rev above 9K to peak out. you need make power under the curve, especially with the torqueless wonder. just my .02.
Rocket
46
Nov 12, 2013 03:02 AM
