So how do i get the Distributor Rotor off? I allready got the screw out the back of it.
Old Mar 22, 2005 | 08:40 AM
SuicideSlide's Avatar
Default So how do i get the Distributor Rotor off? I allready got the screw out the back of it.
So how do i get the Distributor Rotor off? I allready got the screw out the back of it. Does it just pull of?
Old Mar 22, 2005 | 09:33 AM
Rod.'s Avatar
Default Re: So how do i get the Distributor Rotor off? I allready got the screw out the back of it. (TurbLu)
you pull it off
Old Mar 22, 2005 | 09:39 AM
ernald711's Avatar
Default Re: So how do i get the Distributor Rotor off? I allready got the screw out the back of it. (redturb
try using two long screwdrivers and use the middle parts and center so that it sits on both sides of the rotor where it's attatched. to make it simple, try to pry it off with equally on both sides so it comes off. it's probably just stuck because it hasn't been removed before.
twentyhurtz
Dec 24, 2009 04:07 PM
zairas
Oct 25, 2009 10:37 PM
Truman001
May 30, 2006 06:07 PM
LoseRPunKx182
Jan 19, 2006 02:01 PM
DCtwoR
Aug 8, 2002 01:34 PM
