Hi all I have problem with finding the transmission drain plug oil
Old Mar 22, 2005 | 07:41 AM
maivietla's Avatar
Default Hi all I have problem with finding the transmission drain plug oil
I have a honda accord 94 ex, i know where the dipstick is but i have troulbe finding the drain plug of the transmision, by the way this is automatic transmission. Thank a lot.
Old Mar 22, 2005 | 09:14 AM
sj993's Avatar
Default Re: Hi all I have problem with finding the transmission drain plug oil (maivietla)
It's on the right side of the transmission. Near the bottom.
Old Mar 22, 2005 | 10:05 AM
Stew Pidasso's Avatar
Default Re: Hi all I have problem with finding the transmission drain plug oil (sj993)
It may not be a bolt type plug. It may just be a plug with a 3/8 socket hole in it. Just stick your 3/8 socket extension in the hole and open it up. Not sure which is on your vehicle.
Old Mar 22, 2005 | 03:32 PM
BAYDREAMER's Avatar
MY 90 plug was seized up and no breaker bar could break it, Thank God I did not screw it up. Instead cheap 5 dollar plastic hand pump sucked all the transmission fluid out, 4.5 qt through the dip stick hole as indicated by honda manual.
Old Mar 22, 2005 | 07:02 PM
i20ar's Avatar
if you could remove yoru right from wheel it would be much easyer but if not its on the right side of your engine it doesnt look like a normal plug ull have to use Stew Pidasso's method if you want to try or use BAYDREAMER's method...
take a look at this buddy its a full write up...
http://www.honda-acura.net/forums/sh...ad.php?t=43218
donnieb22000
18
Jun 26, 2018 10:20 PM
Peter_404_21
Dec 30, 2008 08:54 PM
vannak_5415
Oct 6, 2008 05:34 PM
MI4$DC5
Mar 11, 2006 07:56 PM
crxgator
29
Jul 17, 2004 05:48 AM
