how many oxygen sensors has the type R
Old Mar 22, 2005 | 03:58 AM
hondastreet's Avatar
Default how many oxygen sensors has the type R
I baught JDM B18C-R engine 1996 spec OBD2,
I only have one oxygen sensor in the down pipe. I think that i need two oxygen sensors, one before the cat inlet and one after the cat outlet. Is that right?
Hugo
Old Mar 22, 2005 | 04:00 AM
1999all_motoR_teg's Avatar
Default Re: how many oxygen sensors has the type R (hondastreet)
JDM ITR motor is OBD2A it only comes with one O2 sensor. The USDM which are OBD2B come with a primary and secondary
Reid's Avatar
Global Moderator
The JDM ECU does not require a secondary oxygen sensor.
Old Mar 22, 2005 | 08:25 AM
Spunkster's Avatar
Default Re: how many oxygen sensors has the type R (1999all_motoR_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999all_motoR_teg &raquo;</TD></TR><TR><TD CLASS="quote">JDM ITR motor is OBD2A it only comes with one O2 sensor. The USDM which are OBD2B come with a primary and secondary</TD></TR></TABLE>
Please don't post if you can't give acurate information.
96-99 USDM Integras are all OBD2a and require the same O2 sensors as a 99-01 USDM Integra that is OBD2b.
OBD2b was created becaseu Honda got in trouble with the earlier ecus.
JDM ecus use different circuit boards, do not have as many sensors and are not as strict on emmisions as the US.
typer_696
Jul 10, 2017 05:09 PM
Bbasso
Nov 26, 2007 12:56 PM
HondaHeddie
Dec 1, 2006 05:59 PM
thk
Dec 5, 2003 12:55 PM
