b18c all motor losing power
Old Mar 22, 2005 | 02:22 AM
MR. BAR's Avatar
Default b18c all motor losing power
i just bought a 95 si w/ a 94 b18c. has ctr cams/pistons titanium valves/springs port polished head jdm 4-1 headers complete msd ignition/plugs stage 2 clutch lightened flywheel skunk2 int manifold bored throttlebody gutted cat 12:1 compression unorthodox racing crank pulley but at high rpms i feel big loss of power? Raced a stock probe gt and lost? ecu chipped before new skunk2 i.m.? I dunno what's wrong? Need Help!
Old Mar 22, 2005 | 06:07 AM
Kendall's Avatar
Give it a compression and leakdown test, then report back.
Old Mar 22, 2005 | 06:01 PM
MR. BAR's Avatar
Default Re: b18c all motor losing power (510GSRHATCH)
took to racetune in hayward an the guy told me it could be lack of fuel coming from fuel injectors, needs valve adjustment, compression and leakdown test, and finally adjusted timing, the guy at racetune was super cool and im probably going to have him tune my car after i add cam gears and purchase an fc.
Old Mar 22, 2005 | 07:28 PM
ninor's Avatar
if you need more fuel, you will probably damage if not blow up the motor shortly (I'd guess that motor might be damaged already)
Get that thing tuned ASAP
Old Mar 22, 2005 | 07:35 PM
null.'s Avatar
Default Re: (ninor)
what management are you running?
are you detonating?
how high are you reving?
don't get an FC, although it's good, it's not good for the price. your car is obd1, take advantage of it and save some bucks with uberdata or crome. don't mash on your car until you get it tuned. also you should have done a compression test before you bought the car.
Old Mar 22, 2005 | 07:51 PM
Hybrid96EK's Avatar
Default Re: (eg6junkie)
Anyone else notice he says he has CTR pistons and then "12:1 compression".. Doesn't add up...
B18C1 + CTR pistons = 12.9:1
B18C5 + CTR pistons = 12.5:1
Old Mar 22, 2005 | 08:56 PM
onepoint6i's Avatar
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">Anyone else notice he says he has CTR pistons and then "12:1 compression".. Doesn't add up...
B18C5 + CTR pistons = 12.5:1</TD></TR></TABLE>
lol yup..
...stock injectors= loss of power
Old Mar 23, 2005 | 02:23 PM
MR. BAR's Avatar
my bad stock pistons. oops. and yes should have done a compression and leakdown test before buying, because today in my class did compression test and came out 175 across the board which seemed okay and on the leakdown cylinders 1 and 2 were at 5% but three was like 90%. maybe bad valve i dunoo. can somebody tell me what this means?
Old Mar 23, 2005 | 02:24 PM
MR. BAR's Avatar
does any1 know what 175 equals for rate?
Hybrid96EK's Avatar
Default Re: (510GSRHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 510GSRHATCH &raquo;</TD></TR><TR><TD CLASS="quote">my bad stock pistons. oops. and yes should have done a compression and leakdown test before buying, because today in my class did compression test and came out 175 across the board which seemed okay and on the leakdown cylinders 1 and 2 were at 5% but three was like 90%. maybe bad valve i dunoo. can somebody tell me what this means?</TD></TR></TABLE>
Well, did you hear a hissing sound in the intake manifold when doing the leakdown? Hissing from the exhaust? Thats how you can tell if its a valve. I would bet its a bent valve... thats more common I would say then one cylinder of rings dying.
Old Mar 23, 2005 | 02:29 PM
MR. BAR's Avatar
no hissing noise. after pulling valve cover can i see the bent valve or would i have to remove and pull more parts
Old Mar 23, 2005 | 03:31 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 510GSRHATCH &raquo;</TD></TR><TR><TD CLASS="quote">does any1 know what 175 equals for rate?</TD></TR></TABLE>
There is no set formula to figure it out. Each gauge will show a different reading. Its not about the number, its about the consistency. If your running stock pistons, it should be 10:1.
Old Mar 23, 2005 | 03:32 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 510GSRHATCH &raquo;</TD></TR><TR><TD CLASS="quote">no hissing noise. after pulling valve cover can i see the bent valve or would i have to remove and pull more parts
Your not going to be able to see the bent valve unless its REAL bad. If it is that bad, count on new valve guides, retainers, etc. You will most likley need to remove the head completely to find the problem.
Old Mar 23, 2005 | 03:49 PM
Db1_77's Avatar
I'll agree with that.
I recently had my timing belt skip a beat and bent all 8 exhaust valves. I took the head off and could have sworn they were all good to go.
I put them on the spinner at my friends mech. shop, and sure enough, 8 bent valves.
Old Mar 23, 2005 | 04:21 PM
MR. BAR's Avatar
if the valves are bent will the car still run? My car still drives alright its just slow.
Old Mar 23, 2005 | 04:37 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 510GSRHATCH &raquo;</TD></TR><TR><TD CLASS="quote">if the valves are bent will the car still run? My car still drives alright its just slow.</TD></TR></TABLE>
Yes, it will still run. Not a good idea however.
Old Mar 23, 2005 | 06:17 PM
Gen2Gen3teg's Avatar
(hatch77)
^That sucks to hear that you bent 8 of your valves. The distributor bearing on my 90 teg siezed up a while ago and the cam shafts obviously aren't gonna break so my timing belt jumped a few teeth off but somehow (miracle) i didn't bend any valves or any engine damange. I guess i just got really really lucky cuz the b18 has interference so i should have done some damage
uhhmaysing
13
May 28, 2014 06:56 AM
EleanoR
10
Aug 11, 2006 06:01 PM
StreetracerVL
Mar 17, 2006 08:38 AM
spooncivic28
10
Dec 19, 2005 11:58 AM
GSlowR
24
Feb 24, 2004 08:44 PM
