Integra Type-R Pistons in a B18b block/rods
Old Mar 21, 2005 | 10:44 PM
ScootinIntegra's Avatar
Default Integra Type-R Pistons in a B18b block/rods
Would there be any issues with using ITR pistons on B18B rods in a B18B block? I have heard from some people that you need to shave down some material on the rod. If this is the case, I'd have to abandon this idea for now.
Is there any chance of damaging contact between the piston and rod if I use this set up?
PS I've searched
Old Mar 21, 2005 | 10:56 PM
Kendall's Avatar
You will have to shave the rods just a bit in order for them to fit correctly. Consider JDM P30 pistons as a higher compression alternative that doesn't need shaved rods.
Old Mar 21, 2005 | 11:08 PM
Default Re: (Kendall)
Thank ya, sir
Old Mar 22, 2005 | 12:37 AM
virusiidx's Avatar
yeah just go with ctr pistons, 'irev210' has em for a good price.
Old Mar 22, 2005 | 05:33 AM
Kendall's Avatar
Default Re: (virusiidx)
Of course the CTR pistons also require shaving of the rods.
Old Mar 22, 2005 | 06:23 AM
arw321's Avatar
I have CTR pistons in my LS. They will yield a compression ratio of approximately 12.5:1.
You might want to mention this before advising him to go with these pistons, without knowing what cams he's using, tuning, octane, etc.
Old Mar 22, 2005 | 07:18 AM
project-boosteD's Avatar
Default Re: (arw321)
what kind of pistons could i put in my b18c to raise the compression?
Old Mar 22, 2005 | 09:49 AM
ernald711's Avatar
Default Re: Integra Type-R Pistons in a B18b block/rods (ScootinIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScootinIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Would there be any issues with using ITR pistons on B18B rods in a B18B block? I have heard from some people that you need to shave down some material on the rod. If this is the case, I'd have to abandon this idea for now.
PS I've searched </TD></TR></TABLE>
i have .25 p73 pistons in my ls/vtec. no problems for me.
Old Mar 22, 2005 | 11:13 AM
doood's Avatar
been there done that
Default Re: (gsrcivic147)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcivic147 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of pistons could i put in my b18c to raise the compression?</TD></TR></TABLE>
did you not even read this thread?
Old Apr 5, 2005 | 03:45 PM
HomeDepotMade's Avatar
Default Re: (sticky icky)
hey on the GSR do u have to replace the pistons and the headgasket to get the compression of the ITR?
Old Apr 5, 2005 | 04:22 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 &raquo;</TD></TR><TR><TD CLASS="quote">I have CTR pistons in my LS. They will yield a compression ratio of approximately 12.5:1.
what cams are running? and what kinda numbers are you putting down??? if you dont mind me asking
Old Jun 27, 2005 | 10:22 PM
Carolina Fried Rice's Avatar
Default Re: (projectTeG)
I was told that the mods required to make the itr or ctr pistons fit only costs 4-5 dollars a rod, which seems like it would be well worth it.
EJ8chu
Dec 1, 2008 11:13 PM
Almost
Sep 22, 2004 09:52 PM
hybrid_vtec
12
Aug 11, 2004 12:49 PM
iHave2Cams
18
Sep 10, 2003 06:17 PM
