80k = ?
Old Mar 21, 2005 | 10:38 PM
TeaAddict's Avatar
Default 80k = ?
As I am approaching 80k I was wondering what I need to have replaced/what maintenance needs to be done?
I had a major tuneup @ 60k. (valves adjusted/fluids flushed)
Should I get my clutch, slave/master cylinder/timing belts replaced? Should I bother getting anything besides OEM? Can any of you suggest some OC mechanics?
Thanks.
Old Mar 21, 2005 | 10:43 PM
Kendall's Avatar
The timing belt and water pump are the big things coming up, but changing them isn't really necessary until about 90k. I guess if the motor has seen much abuse it wouldn't hurt to go ahead and get it knocked out. Also, may I recommend a Goodyear timing belt (as strong as a Toda/Greddy belt, but much cheaper).
Old Mar 22, 2005 | 08:44 AM
TeaAddict's Avatar
Default Re: 80k = ? (TeaAddict)
Old Mar 22, 2005 | 03:40 PM
Irish Integra's Avatar
Change the belt and w/pump, you don't want them failing.
As far as the clutch and stuff, don't bother until they need to be changed, there's no real point unless you're not happy with it and you plan a really long trip or something...
Old Mar 23, 2005 | 10:27 AM
TeaAddict's Avatar
Old Mar 23, 2005 | 12:52 PM
Stripped Honda's Avatar
99-0104
do the timing belt service dont worry about the clutch.. if you dont know how to do the timing belt job contact me i do work at home on weekends and evenings with oem parts i am a mechanic
Old Mar 23, 2005 | 02:26 PM
RidinStock's Avatar
80k = almost at 100k break-in for honda motors.
Do you have a helms or haynes? I think they have the different tune-ups recommended by mileage. Otherwise just follow the previous posts...
Old Mar 23, 2005 | 03:37 PM
TeaAddict's Avatar
Default Re: 80k = ? (RidinStock)
i have no clue what a helms or hayness is.
Old Mar 23, 2005 | 06:01 PM
patmcd's Avatar
They are both good service manuals, especially the helms manual.
noogin
Jun 17, 2013 09:43 PM
EF7
Aug 12, 2005 02:17 PM
xstalkrx
Jun 29, 2004 08:03 PM
stock97
May 21, 2003 10:31 PM
3rdGteg
Aug 18, 2002 03:40 PM
