missed 4th hit 9500
Old Mar 21, 2005 | 09:46 PM
joshmycell's Avatar
Default missed 4th hit 9500
went to race a firebird had him beat by about a car then missed getting it into 4th and hit 9500 on a stock gsr head, do you think i could of done any thing to the motor. my teg shakes now but i also just droped it right befor the race, do yall think it is the motor or the drop. thanks
Old Mar 21, 2005 | 09:49 PM
Bay_707's Avatar
whoa 9500 i thought when i hit 8700 it was all over.... How does it shake?
Old Mar 21, 2005 | 09:53 PM
joshmycell's Avatar
Default Re: (Bay_707)
not like dam crazy but the steering wheel shakes a lil and so does the shifter , only when i get around 6000-7000. but there is no valve noise at all
Old Mar 21, 2005 | 10:01 PM
Kendall's Avatar
Give it a compression test and remove the valve cover to check for obvious signs of damage. You may have gotten lucky and not damaged the motor.
98lsskunk's Avatar
Default Re: (joshmycell)
it happens to the best of us i did the same thing shifted into second instead of 4th and it hit about 95k, in an ls though, so if it didnt hurt anything on it im sure your gsr will be fine. if the steering wheel is shaking its probably a steering or suspension problem.
Old Mar 21, 2005 | 10:04 PM
joshmycell's Avatar
Default Re: (98lsskunk)
thanks i will do that tommorw and i hope everying thing is all good
Old Mar 21, 2005 | 10:05 PM
joshmycell's Avatar
but lets just say i did bend a valve or somthing how would i find out ?
Old Mar 21, 2005 | 10:08 PM
Spectrum24x's Avatar
wouldnt a rev limiter save you in this situation?
Old Mar 21, 2005 | 10:10 PM
joshmycell's Avatar
Default Re: (Spectrum24x)
i guess it would of but its kind to late now it happend about 3 hours ago
Old Mar 21, 2005 | 10:16 PM
98lsskunk's Avatar
well actually it wouldnt because shifting to 2nd at 80mph is going to cause the motor to shoot right past rev-limiter. what would save you is the block into the gear, but when you slam the **** out of the shifter (like when racing) you can get it into gear.
turn your car on and listen for any ticking noises if you hear anything , pull the valve cover off and check all your retainers and clearances
Old Mar 21, 2005 | 10:18 PM
joshmycell's Avatar
thanks for the info
Old Mar 22, 2005 | 04:35 AM
sleeper96's Avatar
also check to see if the idle is steady,if you bent a valve the idle would bounce up and down a little.
Old Mar 22, 2005 | 06:14 AM
Backk InTheDA's Avatar
I hate everything
Default Re: missed 4th hit 9500 (joshmycell)
9500 Oh ****!
Old Mar 23, 2005 | 12:38 PM
joshmycell's Avatar
Default Re: missed 4th hit 9500 (iTR2The3rdGen)
got the head off today and sure enough had bent valves and a **** load of carbon build up. poured water in to all of my exhaust valves and only my #4 cylinder held water in it. droped it off at the machine shop today $125 for valve job plus $12 per each bad exhaust valve and $9 for each intake valve that is bad
Old Mar 23, 2005 | 01:04 PM
-iLLuZioN-B18C1's Avatar
i guess it could have been worse
Old Mar 23, 2005 | 01:29 PM
TeamDOHCside's Avatar
if anything you might have bent a couple of valves, it wouldnt cause your car to shake. You might have gotten lucky and just got away with it this time, do a compression test to make sure though.
Edit : sorry didnt see the other posts, im an idiot, but sorry about your valves man.
Old Mar 23, 2005 | 07:21 PM
95lstegman's Avatar
Default Re: missed 4th hit 9500 (TeamDOHCside)
okay, and now since your block is no longer virgin, you should sell it to me. mwahahaha.
Old Mar 23, 2005 | 07:30 PM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98lsskunk &raquo;</TD></TR><TR><TD CLASS="quote">it happens to the best of us i did the same thing shifted into second instead of 4th and it hit about 95k, in an ls though, so if it didnt hurt anything on it im sure your gsr will be fine. if the steering wheel is shaking its probably a steering or suspension problem.</TD></TR></TABLE>
wow what kind of internals do you have to give you a 95,000 redline?
Old Mar 23, 2005 | 08:09 PM
drussell4801's Avatar
Default Re: (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">
oh jesus.
I knew it was there before I got to the bottom. LOL
typos are funny.
Old Mar 23, 2005 | 09:07 PM
SumKrazeeDoode's Avatar
Default Re: (drussell4801)
I did the same thing last nite. missed and went all the way to 8200 rpms on a LS. It ran fine today though, no weird sounds or anything coming from the head, but ive heard stories of peoples engines exploding after like 300-600 miles after a miss.
Manny1987
Suspension & Brakes
Jul 31, 2009 06:21 PM
stevescivic
Feb 17, 2008 06:31 AM
FURACERMAN
Nov 6, 2004 11:33 AM
OTT
Mar 12, 2004 11:12 AM
