gsr oil squirters in gsr
Old Mar 21, 2005 | 07:52 PM
turbo_b16_ex's Avatar
Default gsr oil squirters in gsr
alright as everyone knows ls blocks are easier and cheaper to come by then gsr. the main downfall is there are no oil squirters. what i want to know if it is possible to install squirters in an ls. Maybe drill outa hole in the same position as the gsr, then thread it, teflon, ect. Im just curious if this has ever been done. thanks
Old Mar 22, 2005 | 07:08 AM
slowdx's Avatar
i wouldnt do it.
Old Mar 22, 2005 | 08:37 AM
manekDC2.'s Avatar
Default Re: (slowdx)
i wouldnt do it either.. i plugged my squiters up b/c why would you have oil shot onto the piston/rods when more oil can be distibuted towards the bearings.. if you have forged internals or a built motor i would leave the squirters out on any block.. no squiters also helps oil pressure..
-- search
Old Mar 23, 2005 | 09:53 AM
Kwuaymaikrup's Avatar
Default Re: (manikgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manikgsr &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt do it either.. i plugged my squiters up b/c why would you have oil shot onto the piston/rods when more oil can be distibuted towards the bearings.. if you have forged internals or a built motor i would leave the squirters out on any block.. no squiters also helps oil pressure..
-- search</TD></TR></TABLE>
Agreed. But to answer your question, yes it has been done successfully.
turboman2.2
Apr 21, 2010 03:46 PM
viet1337
Apr 29, 2007 02:56 PM
GDM93Si
May 12, 2006 11:15 PM
xvietxkhmerxboix
Nov 16, 2003 05:00 PM
