Relocating brake "valve assembly" (91 CRX Si) Q's?
Has anyone relocated their brake valve assembly? The one right under the passenger shock tower.
What size fittings go into it? They look like 1/8" NPT but I'm not sure.
What size are the lines?
I need to move mine and I was thinking about cutting the stock lines and double flaring them. Then running them through ss braded lines to the valve assembly where ever I decide to locate it.
If you must know why I need to move it, I'm fitting up my Turbo kit and the charge pipe will hit the damn thing. See pics here: https://honda-tech.com/zerothread?id=369711
As you can see, I can't move the charge pipe, hence my dilemma.
TIA
TIA
I'm pretty sure those fittings are NOT going to be a "ASE standard" size. You should try different metric thread sizes...
