eg caster question
wats up guys.. aight when i got my alignment done last year i had more negative caster on the right side.. .5 degrees i think.. i wanted to get the spc caster bolts but it comes with the camber arm.. i already got a camber arm so i dont wanna get the spc one.. who else makes camber bolts?? tia
Modified by vtecenjun at 5:54 PM 3/23/2005
Caster is the position of the wheel horizontaly in the wheelarch.. negative is more to the front compared to the centre and positive more to the back (this could be reversed, but caster is that position anyways)..
Any change in camber/ride height etc.etc. should not change caster.. If your caster is off by alot, then you could have old bushings, or damage you did not know off and the whole suspension is warped/bent compared to the OEM position.
udontknowjack
Mar 9, 2011 06:11 AM
maxQ
10
Dec 5, 2003 07:22 AM
