b18c1 or h22
Ok i have a 94 gsr. My rings are fried and it took a good digger in my cyclinder wall, so i need to get my car running again. My friend wants me to get a h22 for the power (jdm 200 hp and i think 154 or something for trq.) But i want to know if anyone has done this i know that the wiring for the alt. needs to be extended and the starter. I just want to now if it is worth it or should i just get another gsr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bay_707 »</TD></TR><TR><TD CLASS="quote">k20</TD></TR></TABLE>
ok let me spend 6000 on just the motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">It would definately be cheaper to overbore the stock block and rebuild it.
What do you want to do?</TD></TR></TABLE>
i am going to rebuild it i just need to get my car up and running again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numba1 »</TD></TR><TR><TD CLASS="quote"> Just rebuild your original motor. </TD></TR></TABLE>
seriously, just rebuild your motor. You make it sound like your motor has no chance.
but if you wanna just go with a swap, then give me the b18c1
i am going to rebuild it i just need to get my car up and running again while i can build up the gsr it is going to take a while for what i want
Do you like going fast in a straight line or while you're turning? If you like Drag Racing H22(you need modded axles$$$) If you like driving like its supposed to be done, B18c1... The best way to do it=B18c5. *kisses Honda logo*
That motor needs a sleave. When he said took a digger he meant it. Looks like a nut fell in the intake or something with that crap and rattled around before its found its way out HAHA.
I already told you stretchnuts the wiring is easy. Its just the cutting that's a pain in the ****. Once you go H22 you can't go back. I don't know if you want to spend the money on the extra parts you'll need. And I know I don't want to spend the time doing the swap for your punk ***. But whatever you chose is what you chose. I got your back. Better make that choice quick because the little blue bus is leaving in a few days. Just remember how Jeremys bone stock H22 ran. Kick the ish out of any mildly modded gs-r swapped car in town no problem. That torque was awesome. But we spent a lot of time getting that thing in there perfect. And you can't beat the look of popping the hood to reveal an h22. It's like hondas crappy version of a big block.
BTW it's a b18c because its mad JdM yO!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master »</TD></TR><TR><TD CLASS="quote">That motor needs a sleave. When he said took a digger he meant it. Looks like a nut fell in the intake or something with that crap and rattled around before its found its way out HAHA.
BTW it's a b18c because its mad JdM yO!!!</TD></TR></TABLE>
Your the shizzel finally some info i can use, but now all i need to know is what about the axles. Gsr axles prelude axles or mixed ha ha ha.
You can find full RSX-S swaps for $2800. I've seen 4 or 5 in the past few months on my local board (www.houston-imports.com). I haven't heard of one going for 6000+ since 2003.
i would recommend the gsr. It won't be the hassle of new mounts, wiring harnesses, axles and everything when you can just get a new motor for the gsr you already have.
plus, IMO there are more options for b series motors, but i'm biased, as i have a gsr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master »</TD></TR><TR><TD CLASS="quote">I don't know how axles are a pain in the *** at all. You just use integra axles with an f22(90-93 I believe) half shaft. Pretty easy stuff there. </TD></TR></TABLE>
accrod half shaft
accrod half shaft
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blusmke »</TD></TR><TR><TD CLASS="quote">
accrod half shaft</TD></TR></TABLE> Yeah did I stutter? Either that or you could jack some nice HASPORT axles that will work with the prelude halfshaft.
what u crazy! why waste time on a h22 when u already got a bangin *** motor! just buy a new block or re sleeve the block that u got right now and throw in some new pistons, rings, and rods. i did my 4 under 1200, every thing inside my block brand new, except 4 the crank, but i got it balance so its still all good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL VTEC »</TD></TR><TR><TD CLASS="quote">what u crazy! why waste time on a h22 when u already got a bangin *** motor! just buy a new block or re sleeve the block that u got right now and throw in some new pistons, rings, and rods. i did my 4 under 1200, every thing inside my block brand new, except 4 the crank, but i got it balance so its still all good</TD></TR></TABLE>
i got some hasport mounts, and axels, and an h22 why am i carzy for getting an h22. What does a usdm gsr have 170 hp and 121 trq. Whan an jdm h22 has 200hp and 161 trq. how could you go wrong. Its all about the trq baby. i bought the mounts and axels got the shift linkage. Now all i need do is spend some time on my engine bay cutting a whole for the shifter cables get a fuel rail and matbe and intake manifold. then i will have a dam good motor.
Then just get some type-s cams it will be bad
