HELP Tail lights wont work, not a fuse problem, what now?
Old Mar 21, 2005 | 06:29 PM
dturbo's Avatar
Default HELP Tail lights wont work, not a fuse problem, what now?
I got pulled over the other day for my tail lights. The brake lights, backup, and signal lights all work fine. So first thing I checked was the fuse box, pulled out the fuse and it wasnt broken. Replaced it anyways and still didnt work. Anyone have any ideas on what this could be? It's a 97 Civic LX.
Old Mar 21, 2005 | 06:38 PM
dohcdelsol's Avatar
Default Re: HELP Tail lights wont work, not a fuse problem, what now? (flyazzcivic)
So then its just your normal lights not working?
Try replacing the bulbs. Many bulbs are 2 filiments, one might be burnt out. Or just pull all the bulbs and see which ones are blown.
Have you dont any electrical work recently or at all to your car?
Old Mar 21, 2005 | 06:44 PM
slo blue's Avatar
Default Re: HELP Tail lights wont work, not a fuse problem, what now? (dohcdelsol)
the head light switch may be bad. or a ground problem
Old Mar 21, 2005 | 06:57 PM
dturbo's Avatar
Default Re: HELP Tail lights wont work, not a fuse problem, what now? (slo blue)
Just the regular night tail lights wont work. Head lights works fine. All lightings work fine. Replaced bulbs and they didnt work either. No electrical work has been done to this car since it's just a winter car.
Old Mar 21, 2005 | 07:04 PM
NVturbo's Avatar
O.G. triple O.G.
Take one of the plugs off and check for voltage when lights are on. IF you don't get around 12v...more than likely you have a loose wiring or a pinched wire somewhere.
Old Mar 21, 2005 | 07:17 PM
Master23's Avatar
sounds like the bulb needs replacement...
Old Mar 21, 2005 | 07:24 PM
graveltravel's Avatar
relay.
Old Mar 21, 2005 | 07:36 PM
dturbo's Avatar
Default Re: (graveltravel)
It's not the bulbs, I checked the bulbs. Where is the relay located?
Old Mar 22, 2005 | 02:32 PM
dturbo's Avatar
Default Re: (flyazzcivic)
anyone have any ideas? still havent figured it out myself. Does anyone know how I could check to see whats wrong? Is there some sort of electrical tester that would tell me whats wrong?
Old Mar 22, 2005 | 02:57 PM
i believe the relay is inder the hood on the passenger side. it should tell ya from there.
pilot2007guy
Aug 1, 2018 04:56 PM
chirby17
28
Apr 19, 2012 09:14 AM
lilshady6796
Nov 12, 2008 06:33 PM
sam0218
Nov 19, 2006 04:32 PM
NiceDc2r
May 13, 2004 09:42 PM
