question about compatability of oem cd players
Old Mar 21, 2005 | 06:21 PM
kanzenr91si's Avatar
Default question about compatability of oem cd players
quick, easy question. what oem honda cd players can i use in my 94 gsr? does it need to be obd-1? appreciate any help
JD
Old Mar 21, 2005 | 06:36 PM
ernald711's Avatar
Default Re: question about compatability of oem cd players (kanzenr91si)
it should
Old Mar 21, 2005 | 06:38 PM
sabotage7's Avatar
you can use any that fit. emissions doesnt have anything to do with your cd player! i have a cd player from my 97 accord in my 94 gsr. it has a plug in the back for a disc changer, which i also have, and the antenna only goes up if you select am/fm, not every time like with the stock deck.
Old Mar 24, 2005 | 07:23 PM
Default Re: question about compatability of oem cd players (sabotage7)
oh i assumed wiring changed between models. so a newer integra cd player should be fine then. thanks for the help.
Old Mar 24, 2005 | 07:31 PM
sabotage7's Avatar
yeah, just think, when you go to buy a cd player at bestbuy, its not vehicle specific. even if the plugs in the back are different, all you hafta do is match up the wire colors to each other! good luck!
Old Mar 25, 2005 | 05:52 AM
vtecmissle's Avatar
they use either an fm modulator or a conversion adapter allowing the stock controls to work. For a stock gsr you can get an alpine changer and appropriate cord as that is who made your unit.
Razor.
Audio / Security / Video
May 14, 2011 08:18 AM
rstepan
Oct 29, 2009 11:54 AM
quirarte626
Sep 12, 2009 10:11 AM
bdavis
Aug 3, 2006 06:52 PM
cxSHOE
Mar 3, 2004 09:06 AM
